Weber carb suddenly going to WOT - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-25-2010, 06:08 PM
bigdog7373's Avatar
Of course it's fast
just convert it to cable
  #17 (permalink)
Old 08-25-2010, 06:15 PM
I'm wondering if the shaft or the hole in the baseplate is worn or has a flat-spot, from the "hefty" springs...
  #18 (permalink)
Old 08-25-2010, 06:34 PM
bigdog7373's Avatar
Of course it's fast
It just seems to me like the thing to do is convert it to cable so you don't have to deal with this dangerous situation ever again. There's a reason they don't use your kind of linkage any more.
  #19 (permalink)
Old 08-25-2010, 07:18 PM
EOD Guy's Avatar
The carb is 2 months old, the hefty springs are the springs that Auto zone sells for carb return springs, highly doubt they've worn a flat spot etc....... linkage doesn't appear to be binding any where thru-out it's travel. Question do weber carbs have a sweet spot (resting) and do I need to adj the idle mixtrure screws etc...... I've never done this on a weber so any help would be welcome.
Carb or timing? jstuhl Engine 13 07-28-2010 12:52 PM
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 09:19 PM
backfire thru carb airraptor Engine 11 06-12-2009 02:30 PM
Sputtering at WOT - Help leejoy Engine 4 05-20-2006 05:32 AM
Cleaning Carb Question oldcarguy36 Engine 17 03-04-2006 02:10 PM
