Weber carbs that boil - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2003, 07:54 PM
Post Weber carbs that boil
I'm running four Weber carbs, and recently changed over to aluminum heads. The carbs now seem to boil the fuel in the float bowls much easier than with the iron heads. Is the heat problem directly related to the improved heat transfer of the aluminum heads?
Old 04-24-2003, 08:31 PM
4 Jaw Chuck's Avatar
Post
Most likely, a shield will help. Webers have such tiny fuel bowls this problem will get worse with aluminum heads.
Outlawed tunes from outlawed pipes
Old 04-25-2003, 09:32 AM
deuce_454's Avatar
Post
i had a thick (1/2 inch) plastic spacer under my sidedrafht webers on the 4 banger i used to have, to help just that problem.. try and make some spacers from marine grade plywood (1/4 inch should do it) other than that i wouldnt know what to suggest
