Weber I. R. setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2008, 12:47 AM
Weber I. R. setup
Anybody have any experience on these? I was looking around on E-bone and run across these. Are they really worth the cost? Can they flow enuff for a healthy big block?
Old 12-07-2008, 11:00 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
I've run Weber sidedrafts (DCOEs) on a 2 Litre Datsun, that was a pair of 42 mm jobs. Was looking into a set of DCOEs for a Toyota 20R, (2.2L) and even for a stock engine Weber recommends 45s.
The carbs meter by the intensity of the induction vacuum pulse of one cylinder, not the steady-state vacuum like on an engine where the carb is shared amongst many cylinders.
For a built big block with modern cam and head advancements they probably don't make them big enough to make the HP numbers you could get with a single 4 BBL and correct intake. The idle, low-end and midrange is supposed to be great though - if tuned properly. Very streetable.
I love the look though, can't be beat. If I could afford them (and fit them under the hood) I'd run 'em.
David Vizard talks about them in many of his books, that's something to chase.
Old 12-07-2008, 11:50 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If one is willing to do his homework on those they are good and very streetable..A lot of people over carb an engine anyway so i think a set of 48's woudl do it for most apps unless you are turning a big block up in the 8000 range and how often is that? Back inthe day they were the answer but now we have EFI..
Sam
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
My 9inch rear end disc brake setup. 1937FordCoupe Suspension - Brakes - Steering 0 01-15-2007 07:01 PM
weber setup for sale bbc new bwcobra Introduce Yourself 2 02-06-2006 10:58 PM
Is my Torque Converter too big for my setup ?? 74NovaRat Engine 15 02-01-2005 09:23 AM
Setup Question (already running) Got Squeeze Engine 3 12-14-2002 11:53 PM
