Weeping Head Gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2007, 07:12 PM
jleeheat's Avatar
I wanted to see if any of you've experienced SCE ICS Titan Head gaskets leaking before startup. Here's the gaskets I used link
I filled the engine and radiator 2 days ago and planned to fire the engine for the first time this weekend. I noticed very slight leaks from the head gaskets on both sides.
It's a new aluminum SBC decked. New AFR heads checked for flatness. ARP studs torqued to 65ft lbs. & re-torqued days later.
I drained the water back out so I wouldn't contaminate the oil. I also drained a little oil from it to see if there was water in it and there isn't. I just hope I don't have some cylinders with water in them.
My question is, would you just pull the heads or do as SCE recommended and finish the job, bring engine up to full temp. and then let cool completely and re-torque the head bolts.
I'd really appreciate the help.
jim
Old 10-09-2007, 07:24 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Do as reccommended....they are not going to seal untill you get them hot and your re-torque needs to be done after its run also.
Old 10-09-2007, 07:29 PM
nitro_baller4692's Avatar
floppers forever
make sure you are not bottoming out on the stud and that the head is getting torqued and not the stud.i've had this happen once on a small block ford. anyway i would would check cuz are's did not leak tell we sprayed the motor and it lifted the head.
Old 10-09-2007, 08:25 PM
jleeheat's Avatar
Thanks for the reply Henry and nitro... I appreciate it. I'm sure the studs weren't too long...barely long enough as you can see from second picture. I sure hope this thing seals up....kinda makes me want to weep too.
Jim
Old 10-09-2007, 08:44 PM
floppers forever
not to be a wise guy but you did put sealer on the studs going into the block.
Old 10-09-2007, 08:51 PM
jleeheat's Avatar
no sir.....they are blind holes and do not enter water jackets, I just used a little moly and ran them in finger tight. thanks nitro
jim
Old 10-10-2007, 02:31 PM
AHotRod's Avatar
May I ask, Why are you using copper head gaskets ?
Old 10-11-2007, 07:16 AM
jleeheat's Avatar
AHotRod,
If you look at picture number 1, you can see a wire around each cylinder built into the head gasket. It's supposed to provide better sealing, similar to o-ringing block which I didn't need/want to do. I'm using a 144 cu in roots blower and 175hp shot of nitrous and wanted the added sealing capability. If you look at the website link about the gaskets in my first post, you can see a blow up picture of the features of this gasket type if you're interested. It also says they don't leak
Thanks,
Jim
Old 10-11-2007, 07:32 AM
AHotRod's Avatar
I would recommend a FelPro MLS ( Multi-Layered-Steel ) #1142 or #1143 depending on the bore size. They are engineered for extreme cylinder pressure and head lift which is a by product of said. They are used successfully in blown and turbo engines that produce 2000+ HP everyday, and do not require any steel or copper alloy O-rings in the block or heads.
They also come with our special Perma-Torque sealers on the gasket surfaces which elimanate fluid leaks. Another advantage to our MLS design is that the block will have even torque stress, which holds the cylinder walls straighter which produces better and more even ring seal.
Glenn
Old 10-11-2007, 08:03 AM
jleeheat's Avatar
Glenn
Glenn,
Thank you. If these bit$hes don't seal up, I'll look into this gasket you mentioned. Hopefully it wasn't $200 down the drain.
Jim
Old 10-11-2007, 08:17 AM
AHotRod's Avatar
Jim,
I wish you good luck.
Glenn
Old 10-11-2007, 06:32 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Hi Jim, the gaskets I use are Fel-Pro 1014 with steam holes.
Luv the smell of NITRO in the morning.
Old 10-12-2007, 07:16 AM
jleeheat's Avatar
Thank you George
Old 10-12-2007, 09:45 AM
After running a few aluminum blocks and driving one on the street I'd have to say you want to tear it down and locate the leak point. That is a bad sign, in my opinion, that you are leaking water with the engine just sitting there. That would not be normal. Something is amiss.
Old 10-12-2007, 10:05 AM
jleeheat's Avatar
Thanks. I got the impression from the SCE (the gasket maker) that my situation is not that uncommon. The first question he asked was "How much is it leaking?" I don't know whether or not to believe the guy but after Henry Highrise's comment and the manufacturer's comments, I'm inclined to give it a try and see if a re-torque after a full heat cycle will work. I do appreciate your feedback and experience though. You may very well be right. I think I already know where the leak is coming from, two small holes between and at the bottom of the blocks deck. I'll report back with the results for those that give a rats butt.
Jim
Vortec Head and Intake Gaskets Chevy21 Engine 2 05-26-2005 04:04 PM
Head gaskets??? chevyelc81 Engine 2 06-01-2004 09:06 PM
Head Gaskets twoteam Engine 1 03-17-2003 11:50 PM
SBC Head gaskets.....which ones? TheZaZ Engine 6 03-15-2003 10:36 AM
Head gaskets onehotchev Engine 1 03-08-2003 04:09 PM
