"Weeping" SBC water pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2010, 02:51 PM
XNTRCI-T's Avatar
AKA Lee in KC
I have a Weiand aluminum SBC short water pump with maybe 2,000 miles since new. It has begun slowly dripping coolant out the weep hole at the back of the pump... maybe a tablespoon a day right now. Is this an indication of impending failure? Where does the coolant come from when it weeps?
Old 06-21-2010, 02:56 PM
T-bucket23's Avatar
Wiki Edits: 26
Yup, you need to change it. The coolant is leaking by the seal and down the shaft. Usually this is the beginning of the end.
Chet
Old 06-21-2010, 03:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A seal is failing. Seems to happen a lot to pumps that are run w/just water, and nothing else.
Excessive heat (not just hot coolant) can damage seals, a bad finish or too much run out of the shaft can cause seal trouble. Over tightening the belt(s) will do in bearings, but usually not bother the seals.
There are water pump rebuild kits and INFO available, whether the Weiand aluminum pump you have is able to be serviced, I don't know.
OLDS 403 Engine Water Pump bandit79jun Engine 3 02-24-2009 04:30 PM
Shortest SBC water pump Chris Kemp Hotrodding Basics 6 02-10-2009 03:39 PM
High flow water pump for SBC 350 75gmck25 Engine 7 05-22-2007 03:42 PM
Electric water pump, what gpm? New fan? 84Z Engine 4 02-01-2007 05:30 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
