Weiand 142 on 350 Vortec? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2010, 05:54 PM
Ok so my brother bought a stock 350 vortec with low miles and we rebuilt it with new rings and bearings, the heads were reworked with 2.02s/1.60s, zz4 cam, 1.6 roller rockers, msd ignition, air gap etc. It runs and works very well but he wants more power out of his car now. He wants to put a 142 on it. Will this work good on this engine or is it too much compression? It is just a good driving 55 chevy, not a race car. What is a good carb for this setup with a 4-speed manual and a 3.42 rear? Thanks.
Old 01-27-2010, 06:47 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
How much compression does the engine have? The 142 works great on the 350. I put one on a 9.7:1 350 with 5 psi boost. I did have to mix race gas because I had higher than recommended compression but the difference it made was huge.
Old 01-27-2010, 06:51 PM
I think it would be 9.4:1 because it has the stock pistons. I just realized the Vortec kit is WAY more money than for old style heads!
Old 01-27-2010, 06:57 PM
Blazin72's Avatar
Wiki Edits: 19
If it were me I'd do it. Even if it meant bringing the compression down a little to get it to run on 92. The difference a supercharger makes is huge. Plus it's got the wow factor that N/A engines don't have and sounds awesome under heavy acceleration too.
Old 01-27-2010, 09:46 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I like this idea ... go to the Weiand web site and down load the installation procedure it will tell you all you need to know .. answers the compression question nicely ........... go to the source .
ARE 305 and 350 VORTEC HEADS SAME badriand Engine 39 04-06-2011 08:40 AM
Chevelle 307 to Vortec 350 swap--oil pan? 307malibu Engine 5 06-25-2008 03:22 PM
Vortec 350 gasket ? Artemis Entreri Engine 3 09-15-2007 11:56 AM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
1997 350 Vortec Questions bobfray Engine 6 11-28-2003 01:15 PM
