Weiand 144 Blower Problem?
Hi Gents,
I have just installed my new 144 blower on my stock sbc, (following the install instructions meticulously), and started it up yesterday for the first time. I have a rattling sort of clattering noise happening at idle, around 650 revs, and it seems to go away when the revs are increased to around 900. The noise sounds like a rattle or a dry bearing and seems to come from the snout area. I am new to blowers so I'm not sure if this sound is normal or not. I thought it might have been coming from the belt tensioner. Has anyone had this issue? Any help appreciated!! Thanks |
oil level is about 1/3rd the way up the sight glass
See if you can associate the rattling to the belt and belt tensioner. Have you double checked the belt tension after running it, or is it a serpentine system? What weight oil does it call for in the front cover? Are you idling the car at 650? Do you have a way to post a video?
Jason |
This is standard on these bloweres. Mine and everyother one I have seen make the same noise
Chet |
Thanks for your replies guys
I just contacted Holley to get to the bottom of this and they advised the noise is normal on these blowers at below 1000rpm....they say it is gear lash and nothing to worry about Cheers |
I listened to my Blower Shop blower and it has the similar noise too. Low idle only.
Jason |
| Blower Problem | BatesTrucks | Introduce Yourself | 1 | 11-29-2006 07:37 PM |
| heater blower problem (help it's getting cold!) | budynabuick | Electrical | 6 | 11-07-2006 04:30 PM |
| 89 Suburban 700R4 Problem | JoeB | Transmission - Rearend | 13 | 11-06-2006 03:56 PM |
| Puzzling temperature problem on the hemi solved | Centerline | Engine | 2 | 11-26-2004 03:48 PM |
| Toyota Camry Blower Motor Problems | donemore2003 | Electrical | 12 | 11-11-2004 10:45 PM |
