weiand 177. anyone take one apart? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 01:04 PM
weiand 177 blower
this is probably a stupid question, but how do i drain the oil out of the 177. i took the fill plug out and turned upside down no oil came out. the manual says fill oil to bottom of sight glass. theres oil in it. thanks
Old 01-16-2011, 10:34 PM
bigdog7373's Avatar
Of course it's fast
I would guess there's a drain plug at the bottom.
Old 01-16-2011, 10:41 PM
NOlowrider's Avatar
US Navy-Retired
I am not too familiar with the 177, but you can take out one of the screws on the bottom of the front cover. That should allow the oil to drain. Just have something to catch it when it does.
I only have about 4 hours on my 6/71, so I have not came to that bridge yet.
Old 01-17-2011, 12:26 AM
i cant seem to find anything. the instructions say oil level should be at bottom of sight glass. ive taken fill plug out and turned blower every angle and oil does not want to come out. sight glass shows oil at bottom. baffled! next question will be about the water meth injection. thanks for input.
Old 01-17-2011, 12:56 AM
471A
The B&M/Weiand/Holley 144, 177, and 250 use the same dual rotors cut from a common extrusion, just each one longer than the other from 144-250. Consequently, the front covers on these blowers are similar, if not identical. There is no oil within the blower case itself. Rather, the oil feeds the gears in the front cover. Without removing the blower from the engine, one can remove the sight plug. That plug, as you note, is the measure for the oil level, the appropriate amount intended to be at the bottom of the sight plug when the engine is cold. Look closely at the sight plug and you should see either two or four slots on the perimeter which will accommodate a blade. I remove the sight plug by using a thick feeler gauge as a screwdriver to remove the sight plug by threading counter clockwise. I then match hose from a hand-held suction pump to the now open drain at the front of the blower, taped to the blower cover so that suction can truly pull instead of leak, and extract the oil by using the draw, and not the "push" of the suction pump. There also is, at least on the 144 and 250, a drain plug on top of the front cover which, when one turns the blower upside down, allows oil to drain out. Unlike the method I use, however, draining oil from an opened fill slot atop the front cover requires removing the blower from the engine. My Rube Goldberg concoction works fine, combing use of a feeler gauge as a screwdriver and duct tape to seal the inlet to render a hand-held suction pump as an efficient means to extract oil from the front cover. This allows removal of oil without having to pull the blower, along with the fuel lines, carbs, throttle linkage, fuel lines, etc.
Old 01-17-2011, 01:42 AM
deckofficer's Avatar
Last wiki edit: List of hotrodding forums
Last journal entry: Trans swap
Wiki Edits: 12
This is for your 2nd question. If not running an intercooler, and you want to run more boost without detonation, then a 50/50 mix of water methanol will evap in your compressed side and cool that intake charge quite a bit. I have done this on 2 different rides and on one of them I just used a headlight washer pump (they run at a higher pressure but lower gpm rate than a windshield washer pump), a boost activated switch and a mister nozzle.
Bob
Old 01-18-2011, 12:48 AM
Regarding the water meths injection I have installed a system by Blowerworks. Only recently got the thing to work properly though. The fancy map sensor and black box just didn't seem to work. I now have a simple pressure switch sensing manifold pressure which starts the pump. I inject above the blower below the carbs. You should have a cut off valve which prevents suction of water meths when manifold vacuum exists which is often. Otherwise you will be sucking water meths when its not required. I have two injection nozzles .040 each injcting around 30 gal per hour. When ater meths on AFR fattens to around 10 in my case which helps avoid detonation too. May need to fine tune this though.
Old 01-18-2011, 11:33 PM
i bought the charger used, i tried to put oil in and it sits on top and doesnt go in. weiand thought there might be something wrong with casting. has anybody encountered this problem before. im trying to avoid tearing the whole thing down knowing i should. thanks for all the replies
Old 01-18-2011, 11:59 PM
471A
Keeping in mind that the sight plug is removable, why not remove that plug then, with the oil inlet also opened on top of the front plate, try a shot of compressed air into the now open sight plug slot. If no oil, and no air, comes out the top through the open oil inlet, then there may indeed be casting slag, or a mis-manufactured front cover, blocking the path for lubricant.
Old 01-19-2011, 12:12 AM
thanks for the tip. try tomorrow
Old 07-22-2011, 06:27 PM
weiand 177 noise
im starting to get a loud wine on supercharger. not the normal noise but one that sounds like a bearing or something is starting to go. havent put much time on blower but think its time to figure it out. my first problem is something is blocking the oil from going in or coming out. if i take the sight glass out and spray some air down the fill and nothing comes out, can i take the case off the nose to look. when i spoke to blower shop they said i need to measure all the tolerances as i take apart. wondering if there was a casting flaw i could fix. thanks for all the input
Old 07-23-2011, 01:13 AM
wanna thank everybody for their input. just took my front cover off and cant figure out how the oil gets into the case. where i fill the oil in the blower has a valley that has no hole to drain oil into case. bought the blower used and when i got it i couldnt drain the oil or add to it. anyway its the half moon slot in the 2 pictures. im assuming its a manufacturing defect and they forgot to drill some holes or slot. just wondering if its okay to drill a hole or two. thanks
Old 07-23-2011, 08:33 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Your pictures are confusing, too close. Here's a picture from Holley of a 177, I can't orient your pictures to match the fill hole in the front cover in relation to the sight glass. I seriously doubt they forgot to drill holes and don't see where that half moon space even holds enough gear oil to do any good. Is the blower upside down in your pictures?
It looks to me like the fill hole on the upper left of the cover goes right into the main gear case in the picture.
Semper Fi
Old 07-23-2011, 08:49 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Multiple posting merge
A thread of yours of the same issue and this one have been merged.
Semper Fi
Old 07-23-2011, 09:12 AM
Clint Cummins's Avatar
hey,
Is no oil coming out because they shipped it to you with no oil in it?
Add oil to appropriate level.. crack open low bolt to see if oil begins to flow. Close bolt.
Make sure compressor oil is appropriate level before starting engine.
454 weiand 177 ekacpuc Engine 2 01-22-2011 07:14 PM
weiand 250 on BB? Roald Engine 2 11-17-2009 05:55 PM
weiand 177 vs 250 Roald Engine 10 06-02-2009 01:59 PM
more weiand 144 ?'s cochino12 Engine 5 11-16-2008 12:53 PM
Weiand Stealth and Weiand XCELerator intake manifolds...best one?? TheZaZ Engine 5 09-08-2006 07:25 AM
