Weiand 6-71 or 8-71 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2013, 11:38 AM
Fang16's Avatar
Last journal entry: Project change
Weiand 6-71 or 8-71
Bought a blown 350 sbc from a widow. She knows nothing about the engine. In the process of tearing it down. Question is: how can I tell if the blower is a 6-71 or a 8-71? The gears on it are 34 drive and 38 top but I think both their blowers come with this gearing.
Old 02-11-2013, 12:53 PM
33Willys77's Avatar
If I remember right, the case lenght of a 6-71 is about 15" and the case length of an 8-71 would then be 16". This does not include the bearing plates. I dont have mine available at the moment to measure, but if I am wrong, someone should be able to step in.
Old 02-12-2013, 07:01 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
This may help:
http://www.holley.com/data/TechServi...ech%20Info.pdf
Here's the information from Weiand. The case dimensions are on the last page.
The Following User Says Thank You to steve392 For This Useful Post:
Fang16 (02-12-2013)
Old 02-12-2013, 08:13 AM
Fang16's Avatar
That did the trick! Thanks Steve
Old 02-12-2013, 08:37 PM
bentwings's Avatar
bentwings
33 willys is right....6-71 is 15" and the 8-71 is 16". Measure only the rotor section. Usually the 8-71 extra length is to the rear....some are to the front too.
There is also a small case 6-71 which has a smaller bore but the same exterior dim. Makes a great blower for 350 sbc. Just run it about 5% faster than normal. Very strong case. You can also run them on a 383 with a bit more od. They whistle a little more as a result.
Old 02-20-2013, 12:38 AM
if it looks good, a 6-71, if it looks really big, a 8-71
Weiand 6-71 383Eliminator Engine 2 10-01-2011 01:30 AM
Weiand 6-71 help Blown Camaro Engine 21 08-01-2011 08:57 PM
Weiand Stealth and Weiand XCELerator intake manifolds...best one?? TheZaZ Engine 5 09-08-2006 07:25 AM
Weiand supercharger Michael Bell Hotrodders' Lounge 0 06-30-2006 12:25 PM
WEIAND Supercharger (?????????) rparsons64 Engine 1 06-03-2006 04:13 PM
