weiand 6-71 blower questions - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-12-2009, 12:55 AM
bentwings's Avatar
bentwings
A simple place to put the vac/boost fitting would be in the pop off valve cover. It's the thing with the 2 springs on it at either the front or the rear of the manifold. Just measure the height of the springs before you take the plate off. Reinstall them at the same height. This will be a quick and dirty way to install the fitting. You can put it someplace else later on.
My T-350 is set up without a kick down at all. I just manually down shift it if I need it. I still use the modulator however. If I put the shifter in 2nd it will start out in 1st and auto shift up to 2nd depending on how hard I step on it. Easy driving it shifts pretty quick. I just hang 2nd for a while the go to drive. I can manually downshift at any speed practical. My trans is pretty firm. It has a B&M kit in it.
F-Bird... would it not be better to hook the trans modulator up to the carb as normal. The carb will see variable vacuum depending on throttle position. At WOT it is possible there may be a little higher than normal vacuum in the carb however I would think you could adjust the modulator to compensate for this.. I've only run manual trans with all the blowers I have installed so I'm learning here too. I understand the check valve to prevent the boost from getting to the modulator and you will have very high vacuum at part throttle and coast in the manifold with the blower.
  #32 (permalink)
Old 08-12-2009, 05:18 PM
camaroman7d's Avatar
The plugs circled in the pictures are water ports, they are directly over the water jackets in your heads.
Putting the fitting it the pop off valve will work fine, if you don't want to drill and tap your manifold. Take a look at the back of the manifold on the same surface as the pop off valve, there's usually a fitting or two there.
Your tranny shifting issue is due to the govenor, there are kits out there to modify the govenor and prevent early shifts. I like to make mine manual so I lock out the weights on the govenor. Leave the modulator hooked up and hook it up above the blower, that way you don.t need any check valves. You will always have vacuum above the blower.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Blower engine questions? Roald Engine 10 05-27-2009 07:44 AM
Will A blower cam work with nitrous. 73camaro Engine 3 09-24-2006 12:59 PM
Used Blower -- would you buy? 66GMC Engine 10 08-31-2006 03:38 AM
Lots of Blower related questions?? HemmiGremmie Engine 5 11-13-2005 05:15 PM
blower problem fatrat96 Engine 7 07-05-2005 08:28 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
