Weiand 6-71 Supercharger Compressor price.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2008, 09:26 PM
mrdreex's Avatar
Just found a Weiand 6-71 supercharger compressor for what seems to be a good price..i'm not sure what the parts separated out of a supercharging kit are worth, but I found a compressor for around 200$.. it needs new bearings and seals, but just wanted to find out if this was worth it. Only have one pic of it. Thanks.
Old 03-10-2008, 09:38 PM
59 wagon man's Avatar
unless you have all the other parts you ain't saving nothing in the long run
Old 03-11-2008, 04:28 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
That may not be a Weiand. I have a Weiand on my T and it says Weiand cast in the side of it. It could be a stock 6-71?
Old 03-14-2008, 12:03 PM
camaroman7d's Avatar
Not enough angles in the picture but, it doesn't look like a Weiand to me. It actually looks like a stock GMC blower which, will do you no good on a car engine as it sits. By the time you have it converted and by the missing parts, there will be little to no savings. Not to mention if the rotors or case is bad, if that's the case it will just be a $200 door stop. You have to know what to look for and be careful. I would pass on it.
Old 03-14-2008, 12:26 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Real authentic Weiand kits that include all the parts you need to install a running supercharger are 'only' ~$2500. That may sound high but it really isn't when you figure you are getting a manifold, pulleys and belt, gasket set, and blower that has all new disposables and is under warranty. Piecing one together from cheap used stuff can't compete $-wise in the final analysis.
Old 03-14-2008, 12:31 PM
mrdreex's Avatar
understood, thanks for the info.
Old 03-14-2008, 12:34 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
If it is a GM Blower then you can have it rebuilt and converted for a SBC for about 700.00 from "the Blower shop"
Old 03-14-2008, 12:38 PM
mrdreex's Avatar
well, if I were to supercharge, then it would entail alot more modifications than just buying the supercharger kit. i'd have to get new pistons/heads/camshaft possibly to get the c/r down to usable. that plus body reinforcements so I don't twist my chassis in half (it's a subframe chassis) .. and that can get expensive too. I think i'll wait on it anyways.
Old 03-14-2008, 12:50 PM
Double_v23's Avatar
Oh yeah, no doubt that it is expensive. If it wasn't you would see them everywhere. You could probably bolt on a 144 with 3-5 psi of boost and if your motor is in good shape it will handle it. But there are a lot of things that will need to be changed even for that so it probably is worth it to do it right the first time.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Supercharger? Artemis Entreri Engine 38 02-02-2007 03:19 PM
Age old question. Turbo Vs. Supercharger Andyrew Engine 78 08-19-2005 07:35 AM
Possible/worth it? 3.8L supercharger on 305 chevy Project87c10 Engine 9 12-20-2004 07:44 PM
supercharger problem mad van Engine 1 06-23-2002 10:42 AM
