Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - weiand stealth intake vs Edelbrock rpm intake
Old 10-08-2004, 10:38 PM
lluciano77's Avatar
lluciano77 lluciano77 is offline
Short changed on common sense
Originally posted by killerformula
power band on the stealth starts at idle, the performer RPM doesn't advertise power until 1500 RPM and later-
K
I bet the RPM will make the same bottom end and top end as the Stealth. Some single plane intakes will make the same bottom end as an RPM. A lot has to do with your engine combo. The 1,500 to 6,500 is just a loose guidline.
