weiand stealth intake vs Edelbrock rpm intake - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-09-2004, 06:44 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
What ?
I have a 67' Elelbroke X-C8 cross ram intake on my motor rite now.
Luv the smell of NITRO in the morning.
  #17 (permalink)
Old 10-09-2004, 11:35 PM
lluciano77's Avatar
Originally posted by 1BAD80
The manufactures claim are estimates at best. FALSE !
All the math modeling and flow test are done at all the manufactures, more than one way at that.
I guess they should throw away the flow test machines then. Their tested the same way as a head for flow.
I wish I could guess that close.
I made flow tester's for the oval one on the V8 back in the 80s and could measure the size of a BB difference between ports.
Even Flow must be controlled for all the cylinder's, this is the job of the intake.
Don't forget 1Bad, that the intake velocity has a lot to do with the operating range of the intake. A 400 SBC will have a lot higher intake velocity than a 283. The powerband will start lower with the 400.
Another item to address is the stall and gearing. With a performance converter you only need enough bottom end torque to get you into the beginning of your powerband. With lower gears, the engine isn't under as much load, this will affect the bottom end feel of the car.
  #18 (permalink)
Old 10-10-2004, 12:13 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
I'd just say man, that 1bad knows what he's talking about... he's built these motors professionally and worked on NHRA dragsters....
Not to toot somebody elses horn lluc, I'm just explaining... that anyting ytou and I have thoght of, he's already done.
K
  #19 (permalink)
Old 10-10-2004, 01:41 AM
rifraf's Avatar
Well,I have seen the two on the same car,I tried to tell the guy it wouldnt be a noticable change,but it was his money. All sayed and done,if it was differant neither of us could tell.
Ive been using the edelbrock eps lately,Im real happy with the fit and how smooth the power curve is,for something in that range.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
