Weiand Timing Cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2005, 08:30 PM
Roadsire's Avatar
Last journal entry: Dash mods
Weiand Timing Cover
Hello all
I just bought a old school finned weiand timing cover for my 350 engine and it has spacers for the water pump on it to clear the fins on the timing cover that will push the water pump out about a 1/2" from the block this will I assume cause the pulleys to be mis aligned any what do I need to do to compensate for the pulleys to line up? Thanks for your help
Old 06-15-2005, 10:43 PM
camaroman7d's Avatar
I assume those spacers are for a short style water pump. If you have a long pump you probably won't need them. What kind of car is this going in? (the year is most important). This will tell you if you need or have a long or short water pump. This will determine if you will have issues with pully alignment.
Royce
Old 06-16-2005, 12:40 AM
GoneNova/406's Avatar
more spacers
Old 06-16-2005, 06:45 AM
Roadsire's Avatar
Timing cover
this cover has the spacers incorporated into the timing cover casting, it is going on an 83 350 with a long water pump, I was wondering if i could use a short pump and see if that works. thanks
Old 06-16-2005, 10:35 AM
Oh, I see I have seen those timing covers around. You will have to use a short water pump otherwise your pullies will never line up. Measure the spacers, I bet they are right at 3/4" thick.
Royce
Old 06-16-2005, 10:50 AM
Roadsire's Avatar
Timing Cover
3/4" sounds about right Ill go home and measure it up and see thanks a lot for your help, hate to have to alter it or not be able to use as Im going for that old school look on my truck (54 5 window chevy) check out my journal under roasire and let me know what you think so far....will be updating it with some new pics. once I get the engine and tranny installed, waiting on a torque converter.
Thanks again for all your help
Wrong axle cover? frankenvette Transmission - Rearend 12 08-09-2004 05:23 AM
edelbrock AL timing cover 68chevelle_ss Engine 1 03-29-2004 10:15 PM
Car Cover Recommendations? EricTopless68 Camaro Body - Exterior 1 03-19-2004 09:58 AM
timing cover to pump clearance club327 Engine 3 11-09-2003 12:52 AM
Timing Chain cover '67Pony Engine 2 09-08-2003 11:39 AM
