Weighing for CG - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2008, 06:49 AM
GMracer's Avatar
Weighing for CG
Say I had two trucks both the same style one was dropped 5" and the other one stock height, and I used the stock height one to set up the CG on the dropped one, would that be accurate? I am talking about just the weight, not the actual height I can figure that stuff out on paper, but I need to weigh it and this is eht only one I can weigh currently.
I still plan to put adjustable brackets on the front of the link bars, but I wanted to get it close before hand. Or does the height of the vehicle drastically change the way the weight is disbursed?
Old 02-26-2008, 10:17 AM
540z's Avatar
Brute force and ignorance.....
As long as everything else is identical, dropping the vehicle 5" evenly at all 4 corners will alter its CG, but only in the Y axis. You will have to recalculate for the height change, as long as you haven't raised or lowered either end of the vehicle separately. Just compensate for the centroid of mass.
Old 02-26-2008, 10:19 AM
Last journal entry: frame build
Heighth won't change for-aft weight distribution much. Lowering the front will put a little more on the front axle, but not an appreciable amount.
That said, lowering will have a definte effect on the center of gravity of the vehicle. That is too complicated to go into in a short post. I didnt search it but perhaps there is a tech post about it. There are several very good publications about defining and determining CG and roll center out. For a rod chassis, Tex Smiths' How to Build A Hot Rod Chassis, is very good.
Old 02-26-2008, 11:03 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
There were quite a number of posts here on that subject quite a while back..Try a search and see if some of them come up..
Like the others I do not think the Cg will shift all that much from truck to truck..
Sam
Old 02-26-2008, 11:17 AM
GMracer's Avatar
I know the CG height and stuff will change I just want to make sure the weight will weigh the same being that the truck is higher up, like when I do the lifted front end to get the rear weight I just wanted to make sure the weight technically was the same, but it seems from a couple post on here and another forum it will be fine. The heights and such are being determined so it's not a big deal. Thanks guys!
