weight of a '39 Ford Tudor sedan - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2004, 06:48 PM
New Member
I'm currently building a '39 Ford Tudor sedan, and I'm curious as to how much this thing may weigh when I get it all done. It's all steel, stock frame (boxed front and rear), MII front, 9" rear, and here's the kicker, a 460 powerplant with a toploader.
Any idea what this will weigh? I'm looking for similiar combinations, if yours has a small ford or chevy, I can calculate my potential weight from that if you have yours.
I know a SBC or SBF would be easier to install, etc etc, but I'm an old (well 32 yr old) drag racer, and there's no substitute for cubic inches. THis will be a street driven car, and the torque output of a 460, even a mild build will motorvate me down the road quite nicely and not have to wind the snot out of it to do it Plus the 460 will have aluminum heads, intake and water pump to cut down the weight.
Thanks!
Pat
Old 06-06-2004, 08:48 PM
The same BUT way different.........
The 40 Ford coupe in my picture has a 283, and stock everything else.......
It weighs 2940..........with 1/2 tank of high test.
Aluminum intake and water pump, iron exhaust manifolds with dual exhaust.
