Weight of 454 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2004, 01:31 PM
Big Block Z28
Post Weight of 454 engine
Does anyone know the weight of a 454 Chevy engine, preferably with aluminum heads? I need to use my hoist at the extended position which indicates a max of 500 lbs.
Old 08-25-2004, 12:06 AM
There are some "engine weight" sites on the web, most of which seem to be copies of each other. These quote the BBC as weighing 685 lbs. with iron heads. I don't think aluminum heads would drop it anywhere near 500.
Old 08-25-2004, 05:00 AM
Big Block Z28
Thanks, Jim. I imagine the aluminun heads only reuce the weight by about 40 lbs. or less.
Old 08-25-2004, 05:15 AM
Last journal entry: PICTURE TEST
BBC
A iron headed big chevy weighs 685 lbs.
I think you are going to be over even with the aluminum heads.
keith
Old 08-25-2004, 05:29 AM
Big Block Z28
Yeah, I guess 685 is the number. I'll have to pull the boom back a notch on the hoist.
Old 08-25-2004, 07:21 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
doesn't that figure account for cast iron exhaust and intake manifolds? Take those off and you're down another 80-100 pounds. So probably around 540 pounds right?
I think you'll be fine-
K
Old 08-25-2004, 08:08 AM
Big Block Z28
That's a good point. I hadn't thought about that.
Old 08-25-2004, 08:15 AM
weight
I could be wrong but i always thought the 685 lbs included the intake but not the manifolds????
keith
Old 08-25-2004, 08:19 AM
Big Block Z28
I'm not breaking any new ground with this engine swap, so I think I'll just put the car up on jack stands so that the legs on the cherry picker will clear the lower A-arms and set the boom back a notch to be on the safe side. I have to jack the car up anyway to put the tranny in.
Old 08-25-2004, 08:36 AM
plan
Sounds like a good plan... better safe then sorry!!!!
K
