weight differance between SBC/BBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2012, 09:26 PM
I am swapping my small block for a big block and was curious what the weight differance was between the two motors so I can decide if I need to make any suspension modifications.
Old 02-22-2012, 01:43 AM
327NUT's Avatar
With everything stock and no alum. intakes....about 125-150 lbs.
Old 02-22-2012, 06:55 AM
Nope, more like 300 lbs. A "dressed" small block weighs in the 600 lb. "neighborhood". A BB with iron heads and intake is well over 800, probably near 900. IMO, the single biggest drawback of BBC, the weight.
What type of vehicle?
Jim
Old 02-22-2012, 07:03 AM
GT23T's Avatar
http://www.team.net/sol/tech/engine.html
Old 02-22-2012, 07:07 AM
type of vehicle
The motor is a 68' L88 and the vehicle is a 77' Chevy shortbox with 1/2 ton suspension.
Old 02-22-2012, 02:54 PM
327NUT's Avatar
No Mr. P-body, you're wrong.
Old 02-22-2012, 03:45 PM
T-bucket23's Avatar
Wiki Edits: 26
All things being equal it is about 100-125 LBS
Chet
Old 02-22-2012, 05:16 PM
1971BB427's Avatar
Most SBC powered cars will handle the extra weight of a BBC without any suspension changes. If your prings are pretty old and tired then you'll want new springs, but I wouldn't change to BBC springs.
I swapped my '71 Camaro to SBC springs ack in 1975 for drag racing. I just rebuilt my suspension top to bottom, and replaced the front coils with SBC with A/C springs. Slightly heavier, but still sit perfect with my 427 and iron heads.
Old 02-22-2012, 05:31 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
L88 Really?
Got a bona fide?
Old 02-22-2012, 07:02 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
my 71 el camino was 130 lb heavier with the bbc..
than the 400 smallblock..
per the new england dragway scales.. add alum heads and intake and the difference is moot
Old 02-22-2012, 08:38 PM
1971BB427's Avatar
Originally Posted by starnest
L88 Really?
Got a bona fide?
Doesn't everybody have an L88?
Old 02-23-2012, 04:52 PM
starnest's Avatar
elkyholic
Excluding Corvettes at Carlisle, I've only seen one.
I regret not buying it, but it doesn't matter because back then I would have killed it, or myself.
I'd have to see a picture showing the ME or MG code, the 3946052 casting code, and a note with "Hotrodders" recently dated before I would believe.
Nothing personal, just that the mind can play tricks on us.
Old 02-23-2012, 06:10 PM
1971BB427's Avatar
I know what you mean. Every time someone sees my Camaro is a 427 they ask if it's an L88. Mine is not, but it is a dealer installed Corvette crate motor that was put in the car when it was new.
Old 02-24-2012, 03:06 PM
Jason7504's Avatar
how much weight is saved from alum heads, intake and water pump?
Old 02-24-2012, 07:34 PM
327NUT's Avatar
I would think that you would save around 50# on alum. heads on a sbc and about 75# on a bbc. The intake is around 20# ??? and the wtr pump 10# ??? just guessing...
differance between 2-k primers&epoxys triple 555 nickel Body - Exterior 1 01-15-2012 06:56 PM
size differance GM 350 and LS1 iceman36 Engine 1 03-13-2009 03:22 PM
Some one please Explain the differance? 67 Deuce 4 Me Transmission - Rearend 6 03-28-2005 07:14 PM
Differance Between Relays PU70 Electrical 3 02-26-2005 08:44 AM
Differance between 305's? Mike_82 Engine 2 10-20-2003 10:53 PM
