Weight difference between a SBC V8 and a Chevy V6? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 05:08 PM
Mad Maggot's Avatar
The lean mean donut machine
I am looking at getting some Eibach springs for my Trans Am, and I am debating on whether or not I should get the V8 version or the V6 version. I have a SBC V8, however it is significantly lightened with aluminum heads, aluminum intake, and the removal of smog equipment, etc. Is this enough of a weight drop to be around the weight of an otherwise stock V6 with iron heads and intake? I believe Eibach makes these springs based on the stock weight of these engines so I need to know which to use.
Old 07-07-2005, 06:30 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
I dont know exactly, but Id say the sbc with alluminum heads n intake would be pretty close to an iron headed V6.
The power will be cheaper and more easily attained with the sbc to.
I do however like the V6 motors with there decent power and ease of intallation. Your choice. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 07-07-2005, 06:42 PM
Mad Maggot's Avatar
So you're saying I could get away with running the V6 springs with my aluminum headed V8 in the car? I'm guessing the spring rate on the V6 springs is a little lighter to accommodate the lighter engine weight. If I use the V8 springs I could be riding high on the front end because my engine is quite a bit lighter than the V8's they designed them for.
Old 07-07-2005, 07:35 PM
Id say you would be OK.
At the most it may lower it a slight bit, but I dont think it would be noticible.
Switching springs with the engine in wont be hard. Do the V8 swap and then if you dont like it, swap em out. No need for useless buying if you dont need to. HG
Old 07-07-2005, 07:56 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Is this to lower the stance or improve handling? or both?
Old 07-07-2005, 08:37 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
If I were you I would call Eibach, they're know better than most of us.
Old 07-07-2005, 09:10 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
engine weights
Here is a site with 100s of engines and their weights.
Old 07-07-2005, 09:19 PM
Sbc is 575 as generic weight
4.3 is 475
Since you have aluminum heads and intake and looseing emissions garbage the weight is probley very close and aluminum waterpump wouldnt hurt either
Old 07-07-2005, 10:40 PM
Mad Maggot's Avatar
hey, thanks for that site, bracketeer. You are a wealth of knowledge, as always
I figure I would be very close to a V6 weight, so I will get the V6 version of the springs. Your help here has been invaluable.
