Weight on the rear of an '86 Corvette? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2013, 05:56 PM
Could someone tell me the weight on the rear wheels of an '86 Corvette?
I am using the rear suspension of that Corvette under another vehicle and need that info to choose my springs/shocks.
Thanks!
Old 01-22-2013, 07:00 PM
tnovot's Avatar
Total weight of a coupe is 3239 lbs. If I remember right, weight distribution front to rear is close to 50%.
Terry
Old 01-22-2013, 07:17 PM
vinniekq2's Avatar
that 3239 is close to actual.The corvettes are getting fat again,not to mention SQUARE TAIL LIGHTS
Old 01-22-2013, 07:24 PM
sedanbob's Avatar
Wouldn't you be more concerned with the rear weight of the vehicle you are puting that suspension under? I understand that if they were the same (corvette and your vehicle) you might not have to change anything, but your springs should be sized for the target vehicle. Just my $.02.
Old 01-22-2013, 07:44 PM
vinniekq2's Avatar
Actually the spring rate may need to be adjusted to the application. I changed my spring rate because the new more powerful engine made the car squat really bad under hard acceleration. The height is still the same,just a rougher ride
Old 01-22-2013, 08:29 PM
Indeed, you are right, I am simply hoping that the rear weights of the 2 vehicles would be close enough that I can keep the Corvette parts.
Does not look like it though, the Vette rear is going under my '57 Suburban which weighs about 1945lbs (about 300 lbs more than the Vette) on the rear wheels... Bummer. More thinking is needed, as I do not really like the looks of coil-overs...
Old 01-22-2013, 08:41 PM
sedanbob's Avatar
Can't you just swap the springs like Vinnie? As much as those (and Jag rears) get used in rods, somebody must be making springs for them in differing rates.
Old 01-22-2013, 09:05 PM
vinniekq2's Avatar
many places like corvette specialties can supply any spring/rate for any corvette.
Old 01-22-2013, 09:12 PM
Well, this is very cool, thanks! I had heard about custom-rate Corvette springs but had never looked into it yet. I am glad it is actually available. I did not understand that you had changed the springs on a Vette rear, Vinnie.
Old 01-22-2013, 09:20 PM
vinniekq2's Avatar
wave,anytime,enjoy the project
Old 01-25-2013, 11:41 AM
May try looking up VB&P I have installed about everything they have for my 87 and couldn't be happier they have different spring dares and there all new. Just FYI if you swap out selenite and nick the epoxy coating on any of the composit Mono springs the spring will be short lived and will rot out. It fix the squat you'll need eather the adjustable 4 links from VB&P or a set of modified mounts from Doug rippie but there far and few between and you'll likely benefit from the adjustable links. That rear end is called a 5 link but is set up not much different than a 4 also what kind of power are you looking to put to the ground? The Dana 36 ( from a automatic donor car) is good for about 400 up reliably and the Dana 44 (manual donor car) is good for about 150 up more. They can be beefed up but I would only consider a rear end from a manual
Old 01-26-2013, 12:10 PM
Thanks for all that info. I have the "small" rear end, the engine is a stock 350 TBI, so it is plenty strong!
Old 01-26-2013, 12:53 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Not to drive this thread off topic but the 84-96 C4 Corvettes could be had with square tail lights if it was a LT5, LT4 or LT1 powered car. Also, the curb weight for the C6 corvette is around 3,300lbs. The C7 weighs less.
Old 01-26-2013, 03:10 PM
Banned
how about you use the springs you have and get a beefy set of shocks with helper springs?
Old 01-26-2013, 07:38 PM
vinniekq2's Avatar
took an 07 vette over a scale,it was almost 3700 pounds of fat pig!
My 84 was almost 200 pounds more than my current 81.not worth arguing over,I was just not happy to see how heavy my cars were when I weighed them.even my 65 Acadian was 3060, with a 283 and my 67 chevyII was just over 3000 with a 6
registration was a long ways under actual
setting up the rearend so it transfer the weight to the rear tires TATAs 57 Suspension - Brakes - Steering 10 07-21-2010 09:21 PM
Corvette Weight 57halfton Hotrodders' Lounge 4 09-11-2007 07:17 PM
Rear Weight strikingthematch General Rodding Tech 3 05-18-2006 07:52 PM
Front/rear wheel weight ratio? staleg General Rodding Tech 9 12-16-2005 03:47 AM
Need to transfer weight - front to rear STBR General Rodding Tech 3 11-26-2003 02:20 PM
