Weight And Tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2006, 12:05 AM
Weight And Tires
Hey Guys- I Havent Started My Project Yet, But Am In The Research Stage. Im Using A 71 El Camino 283 W/ 350 Tranny And Stock Rear End. The Front End Will Be A Solid Axle With Hairpins. The Body Will Be A Model A Style Pickup, But Im Gonna Have A Really Long Wheel Base( Enough For An 8' Long Bed). My Question Is, What Size Tires Should I Be Using? Id Like To Use About A 250 In The Rear (about A 9 Inch Wheel) And A 150 Mm Tire Up Front (standard Big N Little). I Know That I Dont Want The Car To Peel Out And That That Combo Should Be Big Enough To Prevent Peel Outs, But What About Punching It In A Turn? What I Want To Know Is, How Small Could I Go In The Rear And Stay Away From Oversteer And What Other Handling Issues Should I Keep In Mind? Thanx For Your Help!
tryin to figure out the weight of truck 5.7s10 Hotrodding Basics 6 01-14-2006 08:40 AM
Additional 50hp from heads, or 200+lbs off the nose from a LW front suspension clip? NLang General Rodding Tech 29 12-15-2005 02:31 PM
Need to transfer weight - front to rear STBR General Rodding Tech 3 11-26-2003 02:20 PM
car still WHEEL HOPS why???? tyson Transmission - Rearend 19 08-11-2003 11:28 AM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 09:54 AM
