We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
View Poll Results: Which do ya like 4 my car?
I like the taller, single plane intake 8 44.44%
I like the lower, dual plane intake 7 38.89%
Id like to pound hemmi's skull in 3 16.67%
Voters: 18. You may not vote on this poll
  #1
Old 12-14-2003, 09:17 AM
HemmiGremmie's Avatar
HemmiGremmie HemmiGremmie is offline
Thumbs up Weight, tranny, gearing and rpm's?
Helllooooo and Merry Christmas.
Got a possible friendly debate question. My Gremlin with me weighs an estimated 2700lbs or so. I have a 2 speed glide and will be getting a 25-3200 convertor. The gearing is 4.56's and I run Mickey Thompson tires that are less than good grabbing.
Question? If I build a 375-425 horse engine for the street, could I get away with running a little higher rise single plane intake over a lower intake with the lighter weight of my car and gearing? My thoughts are that with an intake and cam matched for mid to higher rpm's, I will have less traction problems and wont need the lower rpm's due to the light weight? What ya think?,HG
I was built with the body of a God! To bad it was buddah.
http://www.hotrodders.com/forum/jou...&journalid=2415
Old 12-14-2003, 09:29 AM
87442lover 87442lover is offline
Grumpy
Ummm.. your like poll is closed already.
Old 12-14-2003, 09:30 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Since you say you will be running this vehicle on the street; I'd suggest you use an Edelbrock Performer RPM (dual plane high rise) or if you don't mind spending the extra bucks, an Edelbrock RPM Air Gap (basically the same intake as the RPM with the addition of an air space under the runners and carb base).
I don't think you would be satisfied running any single plane intake for street use due to the RPM range you will be in when driving in traffic in town (unless you drive in first or second gear all the time).
Old 12-14-2003, 12:51 PM
Rubberman2003's Avatar
Rubberman2003 Rubberman2003 is offline
Yep the Edelbrock performer RPM is a good intake, so is the airgap.
Old 12-14-2003, 12:54 PM
poncho62's Avatar
poncho62 poncho62 is online now
poncho62's barnstar
Wiki editor
Wiki Edits: 5
#3 is the obvious choice, but it don't make a car run any better.
I think intake choice has a whole lot to do with many other factors, gears, trans, carb, cam etc.
My 55 chevy had 3.34 posi, holley 780, GM 181 cam, and a Torker single plane manifiold. Worked great, but I think if it was an auto trans, it would have been a dog.
Old 12-14-2003, 06:46 PM
ATMRacerTX's Avatar
ATMRacerTX ATMRacerTX is offline
New Member
I would also suggest you use an Edelbrock Performer RPM (dual plane high rise) They are pretty damn good. Also it depends on what RPM you will be running it at. Single plains are great for high RPM engines
Old 11-10-2004, 09:27 AM
firestone's Avatar
firestone firestone is offline
http://teamrfc.gospelcom.net
It is a little hard without knowing exactly what cam you are going to use, but I would not go with a single plane unless you are running at least a 3500 stall. I would go with a performer RPM air gap.
Adam
Old 11-10-2004, 09:31 AM
poncho62's Avatar
poncho62's barnstar
Wiki editor
Wiki Edits: 5
I know that this thread is a year old, so I won't mention that you are planning on using a blower now.....
Old 11-10-2004, 03:06 PM
Yer killin me Poncho! HG
Old 11-10-2004, 09:28 PM
Max Keith's Avatar
Max Keith Max Keith is offline
Intake
A good alternative would be a Weiand Stealth.
Old 01-24-2008, 03:54 AM
clueman clueman is offline
Those gears are kinda wild for the street eh? I had 5:13 and I tacked out at 35mph I did have a 560 cam and 5500 stall converter.. mellow.
Old 01-24-2008, 10:33 AM
bigbadbowtie's Avatar
bigbadbowtie bigbadbowtie is offline
Bottle Fed
.... this thread is almost 5 years old......
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
