Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Weird clear problem
Old 12-10-2004, 07:52 AM
MARTINSR MARTINSR is online now
Read this "Basics if Basics" Atomization (click here). It doesn't "create" any more solvents. What it does is no atomize so the paint (clear, primer, whatever) is not broken into smaller droplets allowing the "solvents" (thinners, reducers) to evaporate as the paint hits the car. CFM is the "V" in HVLP, VOLUME. That means the "amount" of air, not pressure but the amount. Sort of like comparing a super high pressure water hose with an ocean wave. You need a lot of air to "BUST" up the paint into smaller droplets as it leaves the gun. If you read the "Basics" thru, you will have a good idea.
Don't feel bad, this is a common error.
