Weird click sound coming from rearend or transmission
I have an 86 Cutlass with a built sbc 383 stroker in it. I'd estimate it makes around 450hp. The car has a beefed up transmission (or at least I was told it does). And unfortunately it's running the stock 7.5 rear end. I'm saving up money to put a Ford 9" in it soon. Until then stock has to do.
The problem. Sometimes when I take off from a dead stop I hear a weird kinda click or thud sound coming from around the tranny, driveshaft or rear end. It's not loud, and doesn't occur all the time. I know the rear end doesn't have much life left in it, but I hope it will hold up for at least a few more months.
I know not much info is given, but I explained it as best I could. It's basically just a kinda faint thud. It will only make the nosie like 2-3 times, then no noises until I stop and take off again. I do get a faint whine in the rear end when cruising at higher rpm's in first gear. But other than the thud/click there's no other sounds.
Does anyone know what this sound indicates? It's hard to pinpoint it as this car is very loud and the exhaust dumps at the axle. It's just somewhere between the tranny and axle.
