weird cylinder head issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2011, 03:55 PM
0pyders's Avatar
only the ends of the head will thread to the block.
every other hole i can push the head bolt all the way through like theres no thread on the block just empty space.. i took the head off and the bolt goes in fine but when the head's on it doesn't. what does this mean. I'm sure the heads are on the dowel pins correctly the head meets the intake ends evenly.
Old 01-23-2011, 04:02 PM
u probably have the wrong head to block match up. sometimes the same motor will have different versions that are like 85 percent the same or etc. as long as they are lining up and you arent going to far up into ur valve covers and all the inner workings aline i would just get long bolts and use a huge washer or something.
tell us more about the engine, car, etc. if you have a phone to take pix that would be great too.
Old 01-23-2011, 04:05 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
No. you got the 4 bolts of intermidiate length mixed up. there is a bunch of long ones and a bunch of short ones and 4 mid length ones. you got all the holes on the other head filled with long bolts and now have 4 extra mid legnths.
Look at the parts page you posted. It clearly shows that.
Old 01-23-2011, 04:16 PM
0pyders's Avatar
oh geez I forgot the outside bolt is shorter.
Thanks
I can never seem to figure out the simple parts..
Old 01-23-2011, 04:23 PM
LATECH's Avatar
Thanks
You should look at the bosses on the head where the bolts go through. You should be able to see where the mid legth bolts go. I think it is the end 4 you had diagramed out.you probably only have short bolts left over and they arent grabbing any real estate as the bolts are too short.
Where are they at is something you should figure out. They may have been put in a short hole and bottomed out before they actually contact the head.
Old 01-23-2011, 04:31 PM
0pyders's Avatar
I managed to get all the bolts right on the other cylinder head because the bolts came in 2 boxes.
Old 01-23-2011, 04:35 PM
LATECH's Avatar
Whew!! kool
Then that side is good to go.
Old 01-23-2011, 09:54 PM
Whew!! kool
i guess he'll be driving a 4 cylinder after all..
Old 01-23-2011, 10:44 PM
Commanderkewl's Avatar
Time traveler stuck here...
If I hadn't done that 25 years ago that woulda been funny y'all. Ok it is...
383 Head Gasket issue remist17 Engine 5 11-15-2010 08:27 AM
2001 aztek brake pedal issue after blown wheel cylinder fast68 Hotrodding Basics 1 10-06-2010 08:23 PM
Head gasket issue? v8hed Engine 12 12-30-2008 06:00 AM
Weird Headlight Issue CustomConspiracy Electrical 2 09-21-2008 03:09 PM
Engine rev problem (very weird issue) danbeck Engine 9 12-20-2007 07:30 PM
