Weird dist. problem,please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2008, 02:26 PM
MSD HEI GM distributor.I have the 12 volt feed wire hooked up and I am getting spark when cranking but it is very weak.I have brand new Moroso 8mm wires and I ohmed them out to be sure the problem wasnt there.I hooked up my remote starter and a timing light to #1 plug wire and I am getting nothing on the light,however when I move the timing light clamp closer to the distributor cap the light flashes.I have the engine a tdc and timed properly but it still will not run,the most I get is a sputter every once in a while.Anyone know whats going on?
Also it is a brand new coil,I put a spare one in just to check but still a weak spark.
Old 12-03-2008, 03:05 PM
the dist is working off of batt only volts when cranking....
a worn starter motor or performance build motor will pull the volts and amps available to the dist down low enough to cause a weak spark while cranking....
(headers heat=maybe 1/3rd of a starter normal life span and twice the amp draw after mounted for just a short time period!!!!)
often further aggrevated by resistance in the harnesses to the dist causing more volts and amps loss
read the volts with just ign on at the batt and dist...
read the volts at the batt and at the dist while cranking...
don't know the minumum "turn on" volts for your MSD dist but a pertronix will "try" to make a spark with only 8V while cranking and a HEI won't even turn on without about 11V minimum....
hook up jumpers to a second running car and see if it starts...
(that puts 14V supply and alot more amps available to the starter)
run a jumper, batt plus to the coil plus,,,,run a jumper from the metal body of the dist back to batt neg and see if it starts and runs....
(DON'T leave the positive jumper on there without the motor running for more than a minute, it can burn up the coil)
that bypasses all the car positive side wiring and proves it's not a ground (energy source side) problem...
is it lack of fuel or fuel pressure....
drizzle just a small amount of gas while cranking from a ketchup squeeze bottle (smaller the nozzle tip the better) to see if it will keep chug chug chugging when you turn off the remote starter button with the ign on
post back results?
and more car/motor details please....
Old 12-04-2008, 06:50 PM
I swapped out my dinky wire for a 12 gauge to feed into the coil.Ran the wire right off the battery to a on/off toggle.I put a meter on the feed wire and with the toggle on it was reading 12.2 volts,before it was only reading 9.That problem is solved.I checked all my ground wires and they all checked out.Brought the engine back to tdc with the rotor point at the #1 spark tower.Flipped the toggle ,hit the starter and behold...It lives.I took a minute to time it right and it is running like a top.
Thanks for the troubleshooting advice.
Old 12-05-2008, 08:54 AM
your welcome,,,
what is the car and motor????!!!!!
only 9V at the coil definitely sounds like it was a points ign car and you still have the approx 1.5ohms ballast resistor or resistor wire in the ign circuit...
not likely the teeny wire was the fault,,,,12V/1.5ohms=8V
(but a #12 wire is more correct for the approx 5A? MSD dist to make the best spark possible with the coldest wire ,,, 14Vx5A=70Watts)
"if" it's not due to a ign ballast resistor then it's smart to track down the fault because a wire in the harness may getting pretty darn hot to add the 1.5ohms and can cause a fire....
(can be just a corroded connect or switch contact, got to test to find out)
it's kosher to have a totally "independent" batt ign circuit and bypass the ign switch
(same as wiring 55W fog lights to the batt and thru a dash switch)
FUSED AT THE BATT+ and heavy duty toggle switch is fine, (just like a full time race car)....
it "can" even be configured same as a key theft deterent....
what are you trying to build???
Shimming dist shaft yragat Engine 4 11-25-2008 09:16 PM
396 bbc dist problems Sledgeman63 Engine 6 08-30-2008 01:38 PM
351 w chewing up dist. gears johnsquicks10 Engine 4 02-04-2007 06:04 PM
HEI mallory dist ?????? weedhopper Electrical 5 08-21-2006 07:53 PM
changing from points dist. to electornic dist. what to change? IHAVECHEVYPARTS Electrical 1 12-21-2002 09:20 AM
