Weird Edelbrock carb problem - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-14-2013, 02:33 PM
Fang16's Avatar
Last journal entry: Project change
Originally Posted by painted jester View Post
Ive been running & tuning tunnel rams and cross rams since the 60s LOL I think they are the best intakes for power on normally aspirated engines and are very adaptable for street use for rodders ( I'm one of the few LOL) I ran high front end fat fendered Gasers! The front fenders are like para shoots and will lift front tires right off the track and you lose your steering at top end! It only takes one time to happen to end your racing in a disaster So be careful and take precautions to prevent it!! Don't take for granted it won't happen because it never happened on your other runs! You have no Idea What you feel when your steering is lost at 130 MPH and your drifting into the other lane or the wall!!!!! There is nothing you can do to slow the car fast enough to get your steering back And your life is in gods hands
Your speeds aren't there yet but as you run you are probably like me and will get the car to run faster and faster and lay awake at night dreaming up ways to get more speed out of it! I drilled 3 inch holes in my fenders and hood to let the air out on some of the Gasers I ran, and some I had louvers pressed in them and the hood!
Be careful
Jester
Oh ****! Now u got my attention! Hate 1/8 mile but may have to go to that! Don't thing I'll ever see 130 or even 120. Very many instances of the frontend picking up on these old gasser types.
Shot down a few times in Nam in helicopters. Guessing the feeling is similar. lol
  #17 (permalink)
Old 04-14-2013, 02:42 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I was in the Nam in the mid 60s! Marine corps Great to have another VET on here
I think you missed my added edit! Here it is:
A suggestion I would Make Is get the spacers out from under the carbs and add tubes to fit the carbs bellow the scoop to raise the scoop into the air stream the increased velocity of the air down the tubes will increase power more then the spacers under the carbs and different length tubes will make differences also in the ram effects!
Jester!
  #18 (permalink)
Old 04-14-2013, 02:49 PM
Fang16's Avatar
Jester!
Yep, missed the edit.
68-69 Mid 70-Feb 72. Army
Now there's an idea! Get that front carb out of the wind too. Because of the tunnel ram design the carbs are about an 1" if height difference. Back one sits lower than the front. Tubes are cheap, Lowes here I come! LOL
  #19 (permalink)
Old 04-14-2013, 03:34 PM
Tunnel rams at speed with the velocity through the carb venturis make a V8 like 2 4 cylinder engines so both ends of the plenum need to be of equal sized volume Or you get the front 4 cylinders fighting the back and on some tunnel rams you may need to stagger jet the carbs to get each cylinders fuel air ratio the same! Some tunnel rams have some cylinders that run lean as velocity builds and RPM climbs because of individual engine cylinder characteristics , You also want absolutely open exhaust headers with about 18 inches of collector added off the header collector flanges of the headers! If your headers have a 3 " collector add a 3 inch dia x 18 inch long tubes if 3 1/2 add 3 1/2 x 18 tubes ETC 18 inches is just an average length that works very well! If mufflers or anything else slows down exhaust scavenging you will get a reversion!! Running right off the headers collector does not add to scavenging there is no area to build velocity of the escaping exhaust after it leaves the primary tubes the addition of the collector tube extension blends the primary tubes pulses and the length of the tube increases the velocity and scavenging effect!!!!
You Probably know all that already LOL
Jester
  #20 (permalink)
Old 04-14-2013, 03:50 PM
Fang16's Avatar
Jester
More interesting news, most of which I didn't know. To quote the movie "Almost Heroes" "you want my head to explode!" LOL
  #21 (permalink)
Old 04-14-2013, 04:29 PM
vinniekq2's Avatar
not a lot of guys understand stagger jetting.Its a big thing in BBCs.PJ will do you well here.
  #22 (permalink)
Old 04-14-2013, 09:01 PM
Fang16's Avatar
Interesting concept. Would like to hear more on it. I'll do some searches on it.
  #23 (permalink)
Old 04-14-2013, 09:05 PM
Fang16's Avatar
Originally Posted by F-BIRD'88 View Post
Your driving method is very bad. Get the fugggging thingk into 3rd gear
Shift it at 6000rpm. No wonder you got no mph.
shift at 6000 1-2 6000-2-3. Then try 6500 rpm. Get the thing into 3rd gear.
You cannot track tune/jet a car that is not being driven correctly.
ya it needs a lot more gear..... get it into 3rd right after the 1/8th mile mark.
The car needs 4.88 gears. (30" tire)
Thanks for all the good info. Haven't raced in over forty years and things have sure changed! Making my list now! and checking it twice!
  #24 (permalink)
Old 04-14-2013, 10:20 PM
Its hard getting back into it after many years, Nerves, Adrenalin, young guys watching the old fart and the gasser , You don't want to make a fool of yourself LOL a LOT of us have been there!!!!! The test and tune is a good place to get your confidence back with no pressure while your tuning the car your also tuning your driving skills back to what they used to be
Jester
  #25 (permalink)
Old 04-15-2013, 08:22 AM
Fang16's Avatar
Jester
Didn't get to do it that much back then. Had a senior trip to da Nam that put a hold on things. With the advice from the great group here I'll get better. I was wondering last T-n-T why everybody was taking off so easy. In my day it was wing it up there n let it go. Most of them are pretty quite too, but then, I'm old n don't hear so good. lol
  #26 (permalink)
Old 04-15-2013, 10:55 AM
A lot of cars take off easy and gain speed after leaving the line because their tires wont bite the track! About being quiet I would guess they are running through mufflers! I just did a guys road runner and he leaves the line easy because the first time he left hard it was such a hard launch it scarred the hell out of him! and its a weekend show car he was afraid somthing would break! he built a car for drag and bragging rights but doesn't use it for that. he runs 13s when he drives it, But when tuneing I drove it and its in the 11s! And he was like a chicken with its head cut off watching me worried it would get dirty and then went nuts because hot rubber stuck to his quarter!!!!
Jester LOL
Spell check isn't working So forgive my spelling LOL
  #27 (permalink)
Old 04-15-2013, 11:19 AM
Fang16's Avatar
Jester LOL
LOL Have some guys like that in local club. Blown Henry J has never raced it and now he's thinking about selling it. I've thought about quieting down my ride but kind of takes the fun out of it. lol 13 to 11's, big difference! May go to Mokan on Saturday for some t-n-t before the spring hot rod reunion on Sunday.
Oh yeah! What you were saying about the pipes after headers. I was thinking about doing that and putting some 3 bolt header flanges at the end to connect/disconnect the mufflers. The ball type fitting would probably be better though. Your thoughts? Muffler types?
  #28 (permalink)
Old 04-15-2013, 06:49 PM
That's the way many weekend warriors do it! their exhaust hooked to the 18 inch collector extension. With collector flanges you can bolt your exhaust to the flange while they are open with one bolt to hold it up and out of the way!!
I had Flow masters and about every other muffler you can name LOL and last year I bought Summit welded race mufflers (aluminized) and I like em a lot, but to each their own everyone has what they prefer! A lot of guys with the nostalgia drag cars run baffles on the street or a stackable baffle right on or in the end of the collector They work pretty good !!!
I always say "Drive em the way they were built to run!!!!" But then there are the pretenders and trailer queens LOL
Jester
  #29 (permalink)
Old 04-15-2013, 08:14 PM
Fang16's Avatar
Jester
Looked at baffles a few months ago and wasn't sure about them. Any louder than flow master 10's? How loud are your race muffs? 3" I assume?
  #30 (permalink)
Old 04-15-2013, 08:28 PM
vinniekq2's Avatar
The exhaust does not have to be loud just because the pipes are large diameter.The engines that make more power will fill the exhaust system more efficiently than a whimpy motor.
ever hear a stock honda civic with a coffee can muffler?
Edelbrock carb problem MJS69 Engine 15 11-30-2011 02:38 PM
Edelbrock carb problem turchiac Engine 4 03-28-2011 08:53 PM
Edelbrock Carb Problem. odieboy Engine 8 11-24-2009 02:20 PM
weird carb problem jackflash Engine 4 06-16-2008 04:38 PM
Edelbrock Carb problem? busterwivell Engine 8 07-29-2007 07:49 AM
