Weird Headlight Issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2008, 02:00 PM
CustomConspiracy's Avatar
I have a 65 chevy C10 pickup....2 single headlights,,,,Sylvania Halogen bulbs.
The truck shows no signs of ever being swamped pr flooded.....I drove it from California, and drive it every day.
One headlight has nearly 2 inches of water in the bulb!!!!!!! It works, and has been working for 2 years. The other bulb has lots of moisture droplets inside, but not like the other one.
The water has caused the reflector coating to come off but the things still light up.
I'm changing them out finally because they are really dim now but I am very curious about why they are like this and amazed they keep working.
Old 09-21-2008, 02:13 PM
powerrodsmike's Avatar
Wiki Edits: 161
Crack somewhere...My wife's Mustang had the same bulbs with the same problem, the last time I checked, they still work.
It amazed me that the gas never leaked out...
Later, mikey
BE different....ACT normal.
Old 09-21-2008, 03:09 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
not to knock the fords but ............ they have had water in there tail lights starting in 57, I busted a gut the other day as I pulled in behind a ford suv and damn if the tail lights were'nt half full of water. I thought to myself you mean they still have not fixed that problem ................ very funny.
Or just maybe ford is running a bulb test for underwater pool lighting that started in 57.
Please Help!!! Headlight Issue 1981 Camaro 18camaro Electrical 7 02-23-2008 10:14 AM
Engine rev problem (very weird issue) danbeck Engine 9 12-20-2007 07:30 PM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 03:46 PM
weird headlight problem adrock430 Electrical 16 04-13-2005 09:56 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 07:36 AM
