weird headlight problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2005, 07:03 PM
Hey guys, Hope there is a guru who can figure this out for me, its a 94 ford ranger, 4.0L...my headlights flash after about 20 min of being on. When I disconnect the right bulb, the flashing stops, the left one stays on continuously. I had a previous problem of the right bulb going out, I replaced the headlight assembly, stopped the bulb going out, was fine for about 2 weeks, then this flashing problem started up. I figured it was in the plug, so I replaced it, still flashing after 20 min of driving. Any ideas of what might be causing this? Thanks, Adam
Old 04-02-2005, 07:32 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
wild guess
I would guess you have a short crossing over into your signal light circuit. When the headlight starts flashing. Listen to see if you can hear the signal light flasher.
Old 04-02-2005, 07:37 PM
Never hear that, it flashes on both sides, kind of like I'm in a rush to get somewhere, people pull over sometimes. Don't hear any clicking or see the arrow come up on the dash, its strange. Thanks for the help. - A
Old 04-02-2005, 07:44 PM
bracketeer's Avatar
489 Lemans
burglar alarm
Do you have a burglar alarm or remote start setup? Both of these are tied into your headlight circuit.
Old 04-02-2005, 07:53 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Has it been in a accident i.e. hit in the front and repaired? Flashing on and off, or between high and low beam? Sounds like a lose ground to me. The reason both lights flash is that the headlights are wired together usually the left light has splices that go over to the right light. Try running a temporary ground wire to the light ckt just a jumper wire will do usually the wire is black. and see if it stops flashing. Also could have a lose connection @ the switch or maybe a bad switch. There isn't too many things that will cause that problem. Also the dimmer in the column can be bad Fords have alot of problems out of the multifunction switch on the column. hope this helps ...Ed
Old 04-02-2005, 08:52 PM
docvette's Avatar
Wiki Edits: 12
Lights
Doc here,
In addition to what deuce Said about ground, and Clues about it being in an accident before...may have been mis-wired by whoever did the work...
It sounds like your headlights are wired in Series...one wire feed for both lights...Either power or ground...Causing both to die with the loss of one or the other..
Check to be sure each lamp has a separate run from the firewall plug to the light for power..Then check the ground wire, be sure you have separate grounds for both..in fact, just run 2 new grounds.
Hope it helps!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 04-02-2005, 09:06 PM
NorthStar's Avatar
My Mustang has this same problem 5 seconds after I put high beams on it starts flashing. Once in a while even low beams act up.
I think Ford has put a circuit breaker into the light switch they get old and over sensitive like old people.
Old 04-03-2005, 05:19 AM
docvette's Avatar
Wiki Edits: 12
Single headlight
Doc here,
Another thing that can cause "A" ("single" ) headlight to go on and off at will...is the filament is burned out ever so slightly...and vibrating against the rest of the filament structure causing the light to go on and off...(Ever smack one with your hand to get it to work for awhile? ) BUT that shouldn't effect BOTH headlights..just the one with the burned out filament.
Doc
Innovations
Old 04-03-2005, 02:09 PM
Its never been in an accident, i'm the third owner so I don't know for sure, but if it was, they did a REAL good job. They don't flash hi-beam to low-beam, the lights dim on and off. The weird thing is that when I disconnect the right one, the left light stays on steady. I'll give the ground wire a shot first. Thanks, Adam
Old 04-03-2005, 09:50 PM
I just had the same problem with brand new seald beams on a '68 Mustang!
Nothing against China,but they are chinese.Replaced for old General Electric and the flashing went away...
Old 04-03-2005, 10:35 PM
Old enough to know better
Aftermarket, high-watt headlights will also cause it in some systems. Overloads the factory breaker which cycles on and off.
Old 04-04-2005, 08:13 AM
daimon1054's Avatar
It does sound more like a breaker just because it takes some time for it to happen. It could be ground and that was my first thought but again the time thing is what leads me to think breaker. Do they dim or go out all togther? Could also be in the switch, if it is worne it could be getting hot causing a gap or break in the circuit.
Put a volt meter on the line near the light and make sure it is dropping volts, then find the power wire on the switch and see if it is dropping there as well. Then check the power wire going into the switch and see if it's dropping there.
Old 04-05-2005, 01:57 PM
They dim, they don't go out all together. I'll do those tests, just have to get the meter, needed one for a while now. - Adam
Old 04-05-2005, 03:52 PM
docvette's Avatar
Wiki Edits: 12
Dim
Doc here,
When you say just Dim and not go out...EXACTLY what is happening?
You may have an entirely Different problem...Like an alternator starting to go south...Need more Exact info ...
You will need the meter in either case (and it's a good addition to your toolbox anyway) So get that first.
Doc
Innovations
Old 04-05-2005, 06:19 PM
Bowtie or Die!
sounds like a ground! I bet a dollar against a dough nut you have bad ground or grounds. Lights are dim because there trying to ground threw the filaments and what you think is low power is power trying to get to ground. and the resistance in the filaments heat up = dim light. See it all the time at the shop.
Engine stalling problem JamesRS Engine 3 01-30-2006 12:22 PM
Ignition Problem malibuman66 Electrical 17 01-24-2006 02:05 AM
Overheating problem slik Engine 7 09-16-2004 07:59 PM
Weird problem DoubleVision Engine 5 08-01-2004 09:34 PM
Weird Gas leaking problem....help??!?!?! TheZaZ Engine 5 09-21-2003 02:29 PM
