Weird leak from Holley Fuel bowl - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2010, 12:37 PM
I have a pair of Holley 600's and the front carb has a leak on the side of the secondary bowl
Thing is, it's not leaking from the transfer tube seal, the bowl gasket or the needle and seat seals
It appears to be leaking from the capped side of the bowl near the fuel inlet
I've never had a bowl leak like this, but luckily I have an extra 600 laying around from my old drag boat....
A bit filthy, but has an old style cap seal that probably won't ever leak
I'll get it cleaned up and install it before the cruise tonight, but I'm just curious if there's a fix for the leak (other than buying a new bowl or JB Weld)
Old 10-09-2010, 02:00 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Never seen one leak there either, But your on the right track with just changing it out. JMO
Cole
Old 10-09-2010, 02:04 PM
ericnova72's Avatar
More for Less Racer
About the only fix is to clean it up, rough it up a little with the wire brush on a Dremel or just some sandpaper, and epoxy it over so that it is capped just like the bowl you are replacing it with.
Old 10-09-2010, 02:13 PM
eloc431962's Avatar
Wiki Edits: 37
I have seen some that had been done that way, Just never thought about why now i know.
Cole
Old 08-01-2012, 10:14 PM
So what did you do? I have the same problem. BTW this is the first post i've seen in a week with the problem I'm having. Pics coming soon
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 08:35 PM
650 Holley Puking Fuel Bonger6 Engine 9 07-09-2010 04:51 PM
Holley carb and fuel line question Woodie41 Engine 4 04-13-2009 10:02 PM
fuel leak cjhutch02 Engine 4 01-13-2003 07:41 PM
