Weird Light problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2007, 04:30 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Hey guys,
I need some help figuring out what happend to my marker and blinker circuit, so I can get it working again. The vehicle is an 87 V3500. As it is now, all bulbs are good. The right hand markers, running lights and blinkers all work as they should. The left hand front running light in front does not light, but the side marker does light. The rear running light works. All three blink when the blinker is on.
The unusual part is that the blinker blinks slower on the left side, and the front running and marker lights blink at the same time. On the right side the front running and marker light alternate and blink faster. Also, the right indicator on the dash does not work while the left one stays lit only when the running lights or all lights are on. It does blink in all light positions.
I know the series parallel combination wiring makes some wierd symptoms when a wire is wrong or a bulb is out. As far as I can tell all the wiring is original, but it has not worked right since I got the truck.
I cant find anything wrong....please help.
Old 11-03-2007, 05:47 PM
Wiki Edits: 31
check the fuses. some spade fuse box's let you cross them over diffrent circuits. ( great for pranks )
Old 11-03-2007, 07:43 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
What does it do if you turn the hazard flashers on?
Old 11-03-2007, 07:59 PM
31 five window
Last journal entry: grill and rear end
Originally Posted by TurboS10
Hey guys,
On most vehicles if a bulb is out it will blink faster or slower depending on year. If every thing else checks out it is usually a bad ground. When ever lights do strange things always check all grounds.
Old 11-03-2007, 08:04 PM
TurboS10's Avatar
Wiki Edits: 2
Hmmm...don't know. That is the only thing I forgot. I will go out and check then report back later.
Old 11-03-2007, 08:05 PM
TurboS10's Avatar
Wiki Edits: 2
The more I thought about it, the more I think you are right. I will have to do some searching....which is tough with dual batteries, intercooler and all the hoses stuffed in the nose of this sucker....
Old 11-03-2007, 08:29 PM
TurboS10's Avatar
Wiki Edits: 2
Okay, I have to change one thing after looking at the lights again. The front marker and running light do not light at all except when blinking.
When the hazards are on everything works correctly. All the lights blink at the right speed. In hazard the front right and left marker and running lights blink together.
Strange amps light problem 78transam Electrical 8 12-04-2006 05:46 PM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 11:02 PM
Brake light problems RodFather Electrical 3 07-29-2005 11:45 AM
Choke light WakBordr7387 Electrical 3 06-16-2005 09:43 PM
timing light problems on sbc 4onthefloor 2 Engine 5 03-06-2005 08:47 AM
