Weird Oil Leak - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-30-2013, 06:38 PM
stfinney's Avatar
I just checked my engine and sure enough, both holes close to the fuel pump are open, no bolts at all. Weird that it never leaked before. I guess the thicker oil kept it from leaking out. What is the other hole for anyway? Should I just put a bolt in both spots??
  #17 (permalink)
Old 03-30-2013, 06:54 PM
RWENUTS's Avatar
The bolt holes were originally for front motor mounts. PLug them both with short bolts with a little sealer on them.
Apoligies for me and 10 yearguy for jackin' the thread.
  #18 (permalink)
Old 03-30-2013, 06:55 PM
stfinney's Avatar
Hey, it's cool. No worries for me!
  #19 (permalink)
Old 03-30-2013, 07:00 PM
Yeah sorry it was oil leak related though
  #20 (permalink)
Old 03-30-2013, 07:05 PM
RWENUTS's Avatar
Originally Posted by 10yearguy View Post
Thanks.
I've heard so many different opinions on PCV (necessary or unnecessary) but now that I'm leaking some oil I'm going to try one out as in my mind it makes sense.
But the link you sent was for a breather. I already have a breather on pass side. What did you suggest for drivers side?
The link for the breather, the breather has a hole in the top that you put a grommet and a pcv in and hook the pcv to a manifold vacuum source. Usually on your carb. That style of breather acts like a baffle to keep the pcv from pulling oil thru it. THat type of breather doesn't have vent holes on the underside. It's only open down thru the centre. They look the same until you flip them over. If you don't have a baffle of some kind you'll pull oil thru and not vapours.
The theory behind a pcv is the pcv uses manifold vacuum to pull the vapours from the engine. You need an inlet source(breather) for air to be let in to mix with the fumes. If you have no inlet air source the pcv won't work.
The Following User Says Thank You to RWENUTS For This Useful Post:
10yearguy (03-30-2013)
  #21 (permalink)
stfinney's Avatar
Never in a million years would I have thought to check that bolt hole! At least it is an easy fix though.
  #22 (permalink)
Old 03-30-2013, 07:13 PM
RWENUTS's Avatar
A lot of times that bolt hole isn't drilled quite all the way thru and there's just a thin piece of casting in there which eventually falls out.
I learned all about proper pcv's and leakage points on a motor by trying to run some aluminum valve covers that had no holes in them for a pcv or oil filler too!
Almost lunched a motor. Got to enjoy being towed home 90 miles behind my dad's 440 chrysler in -20F weather.
  #23 (permalink)
Old 03-30-2013, 08:04 PM
Got it. Now that makes sense as I thought that breather was open underneath.
Good deal!
  #24 (permalink)
Old 03-30-2013, 09:21 PM
thinwhiteduke's Avatar
Living In The Past
Na, I didn't think you would...don't mention it, I'm only here to help you!!!
Duke
  #25 (permalink)
Old 04-04-2013, 11:11 AM
Added a simple breather and a PCV breather on the other side with a 3/8 hose straight to the back vacuum port on carb and ran it hard... No more leaks!
Thanks all who had input!
help with weird oil leak oldskool66 Engine 27 02-17-2013 01:56 PM
Weird leak from Holley Fuel bowl 98 SNAKE EATER Engine 4 08-01-2012 09:14 PM
Weird oil leak lt1bbody Engine 5 10-15-2005 08:29 PM
Weird - coil leak !! markn Engine 2 05-02-2004 02:00 PM
400 turbo weird leak! bowwy Transmission - Rearend 7 02-05-2003 07:02 PM
