weird power steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2005, 10:03 AM
GothRod87
oh got a question on my power steering...m 86 grand am sometimes seems like it has a mind of its own...last friday when i parket it the power steering was just fine..alil tight in the left side but workable..this morning i got in to find that it wasnt working...so i pop the hood and check the fluid levels..its empty! so i fill it up and the steering is tight for about five minutes then it getseasy to turn agan and then goes back to normal...im thinking that a bad power steering pump might do this? is this right? my other thought it needs a front end allignment and im wondering if this could be contributing as well? thanks ahead of time,
GOTH
Old 06-14-2005, 11:31 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
GOTH
Other than the the fluid leak, this is very common for an older GM product. It is the steering rack causing the stiff steering, called GM morning sickness. Do you know where the fluid leak is? Fix the fluid leak and replace the rack and you should be all set, also align the front end after the rack replacement. If you cant find a fluid leak, look inside the dust covers covering the inner tie rod end, this can hold fluid without leaking on the ground
Steve
Old 06-14-2005, 12:31 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
morning sickness
Morning sickness can sometimes be fixed with a system flush. Doesn't always work. Pays ur money, takes ur chances.
Old 06-15-2005, 08:42 AM
GothRod87
i looked for a fluid leak couldnt find any anywhere..not on the pump nothing..ill check the dust covers..thanks guys,
GOTH
new power steering pump questions HARVICKx29 Suspension - Brakes - Steering 3 09-05-2005 03:22 PM
Power steering pump hitting box tjh211 Suspension - Brakes - Steering 7 11-16-2004 04:29 PM
Swapping to big block chevy low77ride Engine 5 09-15-2004 09:30 PM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 03:59 AM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
