Weird spark plug situation?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2002, 02:01 PM
Post Weird spark plug situation??
I have a Briggs and Straton 3 hp lawnwower. Today it would not start. I pulled the spark plug wire about 1/4 inch away from the end of the spark plug, plulled the starter cord, and the spark jumped the gap, and the engine started up and ran like a new one. Can anyone tell me what is going on with this?? When I re-connected the wire to the sparkplug, the engine died??
Old 05-12-2002, 02:43 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
I know it dosen"t make any sense, but have you tried a new plug?
Old 05-12-2002, 07:36 PM
Post
I took that same spark plug out, cleaned it with a wire brush and some sand paper, put it back in and the mower started up and ran like a new mower. Still don't understand it.
Old 05-13-2002, 05:02 AM
Steve karch's Avatar
Post
Hi Jim. When you pull the wire it creates a strong spark to jump the gap whick will creat a srtonger spark. This is how we used to start Fords in the middle of winter. Yhe salses dept would flood the motors with extreme regularity a us good folks in service would have to start them. -25 deg or colder. We would pull the coil wire as you did with the spark plug wire, crank the motor and it would fire right up. You probaly have a bad spark plug or its flooded.
Old 05-13-2002, 07:32 PM
Post
Steve,
Thanks so much for that information. I had no idea what was going on there, so its nice to have someone explain it. That spark plug only had a thin film of black soot on it but I guess that was enough to keep it from firing.
