weird steering problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2005, 11:33 AM
bought a 77 trans am to build. the power steering pump was in the trunk. I put it all together and the wheels spin to the left automatically. The hoses have different size fittings so I don't think I could screw it up. I've talked to a couple of people I thought might know about this , but they've never heard of this problem. Please help if you can. I've consulted my Haynes manual and it's useless. I'm not sure what to do next.
Old 06-05-2005, 12:01 PM
aka Duke of URL
Does the system have a remote cooler and/or filter that the lines could have been crossed at?
If you are certain that the pressure and return hoses are hooked to the box correctly, then the problem is most likely in the box. The appropriate year OEM FACTORY SHOP MANUAL will have the diagnostic sequence to ascertain problem and repair.
Old 06-05-2005, 04:04 PM
abstruse dutch uncle
Only time I ever saw that it was the box. It was in an old Chrysler, and a guy I was working with years ago took the box open to try to fix it. He thought he had, reached thru the steering wheel to start the car, and it broke his arm.
A new (rmfg) box fixed it (the car.. the arm took longer).
I have seen a couple R&P units drift one way from a bad rack.
Old 06-06-2005, 12:25 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Hooking a GM box up backwards does nothing but lock up the sector gear. Pressure spikes enough it's possible to blow hyd. lines.
You have a bad steering box. Buy a new one.
Weird clear problem ChrisMiddleron Body - Exterior 40 11-10-2010 06:46 AM
Ford Truck Steering woes Kaylah Suspension - Brakes - Steering 4 08-15-2008 06:09 PM
power steering Paco Suspension - Brakes - Steering 9 10-31-2006 07:02 PM
1999 Tahoe 350 4x4 Steering Problem skyshield Introduce Yourself 6 11-22-2004 05:04 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
