weird suffix code... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2003, 04:52 AM
New Member
hello all,, i have this weird suffix code that i can not make out,,, S730249, and is no mistake,, i am 100% sure that those are the correct numbers, as far as i undestand they should finished off with either 2 or 3 letters but as u can all can see it finishes with 249,,, i was trying to decode that because the casting numbers on the block are unreadable,, 3*7**** ,,, they all messed up.... so i fugure i could decode the suffix from the little pad.. any help would be appreciated,,, tnx.. btw, is a small chevy block...tnx in advance....
Old 07-01-2003, 07:42 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Please go to the Knowledge Base and you will fine a lot of sites for engine ID. you should be able to go through them and decipher the motor that you have comparing to the make and year. Look under engine casting numbers.
Luv the smell of NITRO in the morning.
