Weird Thermostat problem on SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2009, 03:51 PM
Ziggy1805's Avatar
Grand Curmudgeon
Just got the new 350/330 HO crate engine in my 29 RPU and running and now have a thermostat problem I've never encountered.
When the car is cold (first start of the day or after total cool down), the temp gauge goes to 250 and stays there a short while before the thermostat opens, and then it slowly oscillates between 225-250 and 185 where it belongs.
A little more info...
Pulled out the old 305 which had no heat problems, even used the thermostat from that engine. When the first startup did the overheat, got a new thermostat and tested both in boiling water with thermometer and both were working fine.
New thermostat goes in and same problem.
All help/suggestions appreciated.
Paul
Old 05-28-2009, 03:57 PM
what kind of temp gauge?
Old 05-28-2009, 04:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Agree could be the gauge is off. Cole
Old 05-28-2009, 04:24 PM
4 Jaw Chuck's Avatar
Sounds like a gauge problem not thermostat. Where is the probe installed?
Old 05-28-2009, 04:30 PM
Paul
Check to be sure the system is really purged of air, drill a small hole in the thermostat to help it burp. The oscillation in temp makes me think this has more trapped air in there than you might think.
Is there a coolant bypass on this engine? Many guys, especially the Roadster guys, tend to eliminate this for architectural reasons, but the SBC can be cranky without it.
Bogie
Old 05-28-2009, 05:26 PM
T-bucket23's Avatar
Wiki Edits: 26
Bogie
I have that same engine and had the same issue. Replaced the stock thermostat with a Milodon high flow and the issue went away. The cooling system circulating pressure holds the thermostat closed. I had wild swings from 140 to 250.
Chet
Old 05-29-2009, 07:44 AM
Ziggy1805's Avatar
Grand Curmudgeon
To answer the many useful replies:
VDO gauges (same gauges and sender unit as in old engine, which worked fine),
Thermostat has been drilled.
Not running a bypass as the drilled thermostat is "supposed" to act as a bypass.
I will look into the "Milodon high flow".
One thing I failed to mention, changed the water pump to Edelbrock aluminum high capacity. That is the only difference from the original setup.
Thanks
Old 05-29-2009, 09:30 AM
Thanks
I use the Edlebrock pump on most projects and have had nothing but excellent performance from it.
The drilled thermostat does act as a by-pass. The problems are not much of a bypass as the holes are pretty small and the thru the radiator flow increases warm up time.
Typically when you get these oscillating temps, it's a pretty good sign that there is trapped air in the system. I would think with a drilled thermostat that with careful filling that wouldn't be a problem. But I'm always open to surprises.
An other option to consider is that radiator can't handle the flow and the system is surging.
Bogie
Old 05-29-2009, 12:47 PM
Ziggy1805's Avatar
Grand Curmudgeon
Bogie
I agree with your logic except the radiator flow. *ONCE* the temp stabilizes after 5-10 mins, there is no problem at all and the temp stays right at 185 even sitting still on a hot day. I would think that would eliminate the radiator as a problem source.
Paul
Old 06-04-2009, 08:39 AM
Ziggy1805's Avatar
Grand Curmudgeon
T-bucket23, you're my new hero!!!!!
Just finished installing the Milodan thermostat and it *DID* solve the problem. Also with that thermostat there is no need to drill it as it has been modified to bypass a bit.
Thank you mucho!
400 sbc balancing problem Tufel Hunden Engine 13 03-31-2008 06:38 PM
SBC Pulley/Bracket Problem CustomCamper Engine 1 01-20-2008 08:47 AM
Engine rev problem (very weird issue) danbeck Engine 9 12-20-2007 07:30 PM
Weird soldering problem Classix_Lover Electrical 27 11-28-2007 08:54 AM
sbc timing problem..NEED HELP PLEASE!! Steve-0321 Engine 4 03-17-2004 10:33 PM
