Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - weird timing issue
Old 01-21-2013, 08:13 AM
jaw22w's Avatar
jaw22w jaw22w is offline
After you checked for TDC and marked the balancer, did you set the #1 piston at TDC and check to see if it lined up with the tming tab mark? It sounds to me like the timing tab is not in the right place. I would suggest putting a timing tape on your balancer.
