Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - weird timing issue
  #21 (permalink)
Old 01-22-2013, 01:47 PM
bowtie44s bowtie44s is offline
I have the small block cam retarded 4 degrees, the big block is straight up. I haven't messed with the small block for a while. I am adjusting initial timing. I don't know when the mechanical advance starts but i would assume after 750rpm. I have the vacuum advance unhooked and when i slow the timing much below 60 it starts idling rough and will die.
