weird vibrations in 1-4th gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 10:37 PM
hey guys i have a 1986 irocz 28 camaro i recent changed it from a 700R4 to a T5 manual everything works fine but i am having rediculously strong vibrations in 1-4th gear at all rpm ranges if you are moving as soon as i put it in 5th it goes away this one has me stumped any ideas?
Old 03-27-2012, 07:36 AM
Wiki Edits: 49
Had a similar problem once with a '69 Mustang fastback a LONG time ago. Changed out the 3 speed stick for a 4 speed and failed to notice the overall length of the trans on the 4 speed was a few inches less than the 3 speed. Although the driveshaft looked like it fit, it actually was too short and the front spines were only seating on the output shaft a couple inches... which wasn't enough. It would vibrate terribly even in high gear but if I kicked the throttle it would go away completely. Point is... this could happen if there was a difference in overall length of the two transmissions AND if the driveshaft was not re-sized to fit correctly. Just a thought.
Centerline
HotRodsAndHemis.com
"If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
Old 03-29-2012, 02:44 AM
that makes sense but i dont think that is it my drive shaft goes in 3 or 4 inches and the transmissions are the same exact length this one really has me stumped.
horrible vibrations as you rev the car and no vibrations at idle GT350 Engine 5 08-28-2011 04:53 PM
Bad vibrations. Stovebolter General Rodding Tech 13 11-23-2008 09:36 PM
New vibrations, not good vibrations Overdriv Transmission - Rearend 6 02-17-2008 12:37 PM
Vibrations Sonkey Transmission - Rearend 1 03-20-2004 05:02 PM
Bad vibrations propaniac Transmission - Rearend 18 09-13-2003 05:03 PM
