weld it ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2004, 01:16 PM
DARK SIDE's Avatar
weld it ?
I have a grill bar from my 52 buick that is broken. I think it is made of some kind of pot metal. Can this type of metal be welded?
Old 10-18-2004, 03:41 PM
Tazz
DON'T TRY AND WELD THAT!!!!
There are people repairing pot metal...look in Hemmings Motor News....or use and epoxy to fix it from the back....You can use a coat hanger in the epoxy from the broken piece to another piece to strengthen it. Or any other small piece of metal to bridge the repair...get the idea???
Tazz
Rat Rods Rule!
Old 10-18-2004, 11:16 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
you could braze it couldn't you?...
might need to find some silver rod to do it with or your going to have color issues...... unless you could get it rechromed. but i think you could braze it to perfection.
Old 10-19-2004, 09:29 AM
Slickriffs's Avatar
Some of these special solders, such as Muggyweld, are alloyed so you can solder pot metal as well as other metals..I read a post
not long ago hear about some one fixing a tail light assembly with it.
Old 10-19-2004, 02:19 PM
DARK SIDE's Avatar
weld
Thax for all the responses but I think I might have to find a new one because this part is going to be in a spot where it is going to take abuse and I don't think a epoxy will hold and brazing won't stick. I tried it on a scrap piece and it just melted the pot metal.
Old 10-22-2004, 03:51 PM
Last journal entry: Buick
Try these guy's. They sell a pot metal repair kit.
http://www.caswellplating.com/index.html
Old 10-22-2004, 05:09 PM
Dark Side,
I use 60/40 solder and it works great. It melts at a very low temp just a little lower than the "pot" metal. Just use paste flux and a soldering iron and you will have it repaired in no time at all.
Have Fun
Scholman
