Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - weld OR bond on a all steel hood scoop?
Old 01-27-2013, 08:19 AM
HRMC1978 HRMC1978 is offline
I've only done one of these. I used the Valvoline Pliogrip. It was the first time I'd used such an adhesive. I was a little apprehensive about trusting a glue on a hood scoop. So as per the reps instructions I applied the adhesive and then screwed the panel down to the hood. I don't know about other brands but what I was using had micro beads in it so that when screwed down the beads kept you from squishing all the adhesive out of the joint. Once the adhesive was set I removed the screws and welded the holes shut.
