Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - weld OR bond on a all steel hood scoop?
Old 01-30-2013, 10:51 PM
MARTINSR MARTINSR is online now
No foam, it uses a metal sleeve that goes in the rail extending a few inches on each side of the splice. It has a bolt you run down into it and when you tighten the bolt it expands the sleeve which is bonded in.
