Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - weld hood seam 51 chevy truck
Old 04-10-2012, 05:06 PM
skip99's Avatar
skip99 skip99 is offline
alright guys, I appreciate ALL the comments, that's just what I want, I'm no rookie myself, just never welded a 51 hood, so, I tacked it even further apart than your pictures, and then walked away.. I am building a bed at the same time so I can easily move on while it cools, I have learned from my own mistakes too! NOW, did you tack it solid over time, or just fill over the area as is? the 51 chevy hood has a slight depresion, which I think i will just use duraglass over, so, do you think I really need to tack it solid after all?
afterall...my original question was,,,use a filler strip of metal(which means a LOT more welding), or bondo filler..
