Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - weld hood seam 51 chevy truck
Old 04-11-2012, 02:06 PM
robin58 robin58 is offline
Originally Posted by skip99
alright guys, I appreciate ALL the comments, that's just what I want, I'm no rookie myself, just never welded a 51 hood, so, I tacked it even further apart than your pictures, and then walked away.. I am building a bed at the same time so I can easily move on while it cools, I have learned from my own mistakes too! NOW, did you tack it solid over time, or just fill over the area as is? the 51 chevy hood has a slight depresion, which I think i will just use duraglass over, so, do you think I really need to tack it solid after all? original question was,,,use a filler strip of metal(which means a LOT more welding), or bondo filler..
When I did my '53 Chevy truck hood I welded the entire seam. Just a question though, did you remove the hood? I tacked mine while it was still on my truck and all adjusted as it should be. There's quite a bit of flex in some of those hoods and it will be a mess trying to adjust everything if it's off even a little.
