weld on nuts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2008, 03:46 PM
FRANKBULLITT's Avatar
weld on nuts?
is there a way to install new weld on nuts with a welder dont want to tack weld with mig want to have oem look thanks
Old 01-05-2008, 04:15 PM
I have made square nuts from flat stock and plug welded them in for the original look.
Old 01-05-2008, 04:17 PM
weld on nuts
I have the oem ones with the little nubs sticking out just wanted to know how to attach them with welder for oem look
Old 01-05-2008, 04:21 PM
Plug weld them, just drill a hole in the sheetmetal, clamp or bolt them in place and then weld the nut through the hole.
Old 01-06-2008, 08:32 AM
Vortech 4.3's Avatar
jack of all trades
ok, but how do you put a bolt throught it ? i guess i'm missing something here.
Old 01-06-2008, 08:44 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Here is the deal..Drill a small hole in the "nubs" sticking out from the nut and weld through those holes..You may wish to try McMaster Carr as they may have that sort of captive nut with the holes already drilled..
Go to McMaster Carr website and search for nut plates and the various designs show up..
Sam
Old 01-06-2008, 09:18 AM
79C10's Avatar
Viva la Migra!!
Sam
Better be careful looking up "nut plates" on the web....... Only the good Lord knows what you may come up with !!
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Question on Mig Welding - HOW to modas Body - Exterior 43 12-31-2005 09:48 PM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
