• 2.56 and higher gears ("higher" gears have lower numbers, like 2.41, 2.29, etc.) go on the 2 series carrier • 2.73 and lower ("lower" gears = higher numbers, like 3.08, 3.23, etc.) go on the 3 series carrier You can install a 3-series gear on a 2-series carrier by using a ring gear spacer, but this is not advised for stick shift applications, or if there's a lot of traction, HP and/or weight involved. |
Here ya' go:
The limited slip allows the tires to slip. The outer tire in a turn needs make more turns than the inside tire.
When driving straight the differential will work as a single unit rotating both tires. When you make a turn the spider gears will walk allowing slippage so you don't get wheel hop and such. This is important and not a good idea for street driving to weld the spider gears up. |
LOL, I cannot believe someone would do that. Now back on topic, if memory serves me right, you have a 120 volt mig welder running self shielded flux core. IMHO If you are going to weld up the spiders, I would at least borrow/rent/whatever a machine that has more amperage like a 220 volt machine with 70s-6 mig wire or dual shield flux core (electrode/wire positive) because of the better penetration compared to the self shielded flux core (eletrode/wire negative). Just use your dryer plug in and make a extension cord if you do not have 220 volt outside. I'm with colbalt327 and others about this being a bad idea, at least get someone who has done it before or a certified welder (with rigging would be nice |
Welding a rearend gear is a horrible idea for the street, but almost every true drag racing car is using a spooled rearend, and that works the same as a welded up rear, except much stronger. They are not only a good idea for drag racing, but much better than a posi and stronger than a posi too. A spool or a welded rear is a bad idea on the street, but at the track a spool is great. That's where they were designed to be used. And as for lockers; I've run a locker in my '71 Camaro on the street for over 30 years behind a 427, and it's not only worked perfectly, but it's been trouble free. The right locker is a very good option, and often a bit cheaper than some posi units. |
I think we all pretty much agree a spooled or welded diff on the street is NOT a good plan. My take on the relative strength between them is this: Lincoln locker or spool really amounts to much the same thing strength-wise, because either one is still only as strong as the carrier and ring & pinion. But welded has the added chance of breaking due to the welds failing or because of the heat treatment being compromised by welding.
Either one can be too much for stock axles (especially considering the weight of an A-body like the OP's Caprice)- and w/C-clips, we all know what can happen when an axle lets go... Going back to my first car, I used a welded diff in my '55 post w/a 301 and 3-speed manual. Was just dumb luck I didn't have a problem. Well, other than wearing rear tires out, squealing like a pig around every corner in town, and having to plan ahead if entering a parking lot or doing any lock-to-lock steering maneuvering. |
| Weld on or bolt on rear fenders | 1930u | Body - Exterior | 6 | 09-27-2007 07:34 PM |
| 71 nova rear end. weld the axle housings or not? | chevymastermind | Transmission - Rearend | 5 | 03-26-2007 08:39 PM |
| pin holes in weld after welding new metal in under rear window | muskin | Body - Exterior | 23 | 06-19-2006 01:14 PM |
| Odd rear end leak, leaks out weld plugs? | bartamos | Transmission - Rearend | 3 | 12-11-2005 09:56 PM |
| Rear gear choice, Gear to Tow | icegnome | Transmission - Rearend | 3 | 12-03-2002 07:17 AM |
