Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - To weld on springs or not
  #18 (permalink)
Old 12-20-2009, 05:17 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Yes, the design load is the weight per spring it is intended to carry at the load height(compressed amount). Rate is the amount that will compress the spring 1". For say a 200 lb/in spring if 400 lbs is placed on it it will compress 2".
I wouldn't cut them shorter than what you have now, they will settle some after a little use. Only thing you can do is trial and error, and I know iit is a pain, but no pain, no gain
