I wouldn't weld on a spring..
There is no way to fix the spring. Sounds like one is fatigued more than the other, they are from different years or models, or someone has heated it with a torch to lower it. Your smart move would be just to replace them with a matched used set or new ones if they are available or you can find a crossover to another car. Might have to get new from another car brand like Mustang II and cut the flattened coil off if that could get you the correct length and spring rate. Think outside the box if necessary
What is the outside diameter of the current spring?? Ever figure out why you have one a-arm that was shortened?? (different thread) |
You could swap them side for side, install new springs, or trim the high side spring slightly so the ride height will match the low side. Keep in mind that the rear springs can affect the front ride height, that is what wedge is in a circle track car. I have fixed front ride height issues like you describe by repairing rear spring problems. Don't weld on springs!
Andy |
You still might benefit from some fine tuning on the rear coil-overs when you are all done with reassembly.
Andy |
Mustang vs Corvair
The ends of the Corvair springs are both tangential, (twisted on the ends) The ends of the Mustang II springs are one tangential and but the other end is square. So you can stand the spring up on the floor on one end. You can use a cutoff wheel to cut the square end to tangential.
There were 2 corvair springs used with free lengths of 12.7 (162 lbs) and 12.02 (188 lbs). The spring will compress 5 inches with 854 lbs put upon it. If you go to NAPA you can look at the Mustang II springs in the book and get all the specs to make a decision on which spring would be the best to cut. I believe the shortest is a hair over 13 5/8 inches with a 315lbs rate. It would around 9 inches tall with 1468 lbs and 11 inches with 854 lbs. upon it. Just a few things to remember. When cutting the spring with a cutoff wheel only cut about 1/4 of the way at a time and allow to air cool to where you can touch it comfortably. Also keep in mind as you cut the spring shorter it increases the spring rate. I will try and help you with the formula to figure pound rates 11,250,000 times the wire diameter to the 4th power divided by 8 times the active number of turns times the mean diameter cubed Example Note when counting turns on the coil do not count the part that touches A-frame or perch. If you had a spring wire diameter of .500 with 7 coils a inside diameter of 3.5 the mean diameter would be .500 + 3.5 = 4.00 11,250,000 x (.500 x .500 x .500 x .500) / (8 x 7)x (4.000 x 4.000 x 4.000) = 196 Lbs. Hope that helps Dale Cunningham & Hersh Hot Rods |
THANKS
I'm thinking about springs from a Monza,what do U think of these? Qty Coil Spring - Front Product Line: NAPA Chassis Parts Part Number: NCP 2773028 Price: Price Unit : : 65.99 Pair Availability: Call NAPA Store at (724) 929-5522 Features & Benefits Constant Rate Coil Springs Provide A Smooth, Comfortable Ride.; Precision Engineered Coil Springs Are Supplied In Matched Sets.; Coil Springs Support Vehicle Load & Maintain Ride Height For Proper Alignment.; Worn Coil Springs Cause Poor Handling, Improper Alignment & Unnecessary Wear On Tires & Suspension Parts. Warranty Limited Lifetime-See Manufacturers Written Policy Warranty PDF Attributes # Coil Spring Coils : 8.24 Coil Spring Free Height : 13.13" Coil Spring I.D. : 3.61" Coil Spring Load Height : 9" Coil Spring Type : One Tangential End; One Square End Design Load : 1359 Spring Rate : 330 Wire Diameter : .59" Material Safety Data Sheet There is no MSDS for this item E-mail This Item Contact | About | Site Map | Privacy Policy | Terms & Conditions | Powered by NAPA Parts PRO |
These may work
If the ID 3.45 will work these should work fine
Coil Spring - Front Product Line: NAPA Chassis Parts Part Number: NCP 2773084 Price: Price Unit : : 51.49 Pair Features & Benefits Constant Rate Coil Springs Provide A Smooth, Comfortable Ride.; Precision Engineered Coil Springs Are Supplied In Matched Sets.; Coil Springs Support Vehicle Load & Maintain Ride Height For Proper Alignment.; Worn Coil Springs Cause Poor Handling, Improper Alignment & Unnecessary Wear On Tires & Suspension Parts. Warranty Limited Lifetime-See Manufacturers Written Policy Warranty PDF Attributes # Coil Spring Coils : 8.75 Coil Spring Free Height : 14.06" Coil Spring I.D. : 3.45" Coil Spring Load Height : 9.63" Coil Spring Type : Two Tangential Ends Design Load : 861 Spring Rate : 197 Wire Diameter : .5" Material Safety Data Sheet There is no MSDS for this item Application Information: 1980 Chevrolet Chevette Engines : 1.6 L 98 CID L4 SOHC Submodel : Scooter Body Styles : 2 Dr. Hatchback Comments: w/ Automatic Transmission;w/ Air Conditioning Per Car Qty: 1 Engines : 1.6 L 98 CID L4 SOHC Submodel : Scooter Body Styles : 4 Dr. Hatchback Comments: w/ Air Conditioning Per Car Qty: 1 Engines : 1.6 L 98 CID L4 SOHC Submodel : Rally Body Styles : 4 Dr. Hatchback Comments: w/ Automatic Transmission;w/ Power Steering;w/ Air Conditioning;w/ Rack & Pinion Steering Per Car Qty: 1 |
Looks like it will be awful stiff going from either of the Corvair springs at 162 or 188 lbs/inch to 330 lbs/inch(and higher as you need to cut it to get back to your correct ride height).
Edit: I see AMC180mph has you covered while I typed
It's only 50 thousandths, 25 thousandths per side, I would think it would go as a coil spring gets bigger around as it is compressed. Might not completely seat until you have it compressed in there and the front suspension assembled, but it should fit.
another thing is---I'm not sure if these are corvair units that I have?? The 2773084 looks to be similar to a corvair spring. Not sure what the weight of my frontend is ,but the whole car weighs around 2500 lbs,so probably around 1500 of it is in front
| leaf springs | 49dream | Suspension - Brakes - Steering | 2 | 01-12-2009 06:41 PM |
| Can I weld a tab on my front spindles? | Quarter Flash | Hotrodders' Lounge | 15 | 10-09-2006 02:25 PM |
| Consequences of wrong springs on my heads? | TVR383 | Engine | 6 | 11-23-2005 10:25 PM |
| Spot weld driller Shoot out! | MARTINSR | Body - Exterior | 5 | 05-30-2005 05:46 PM |
| Valve Springs | GearHead69 | Engine | 5 | 07-19-2003 11:00 AM |
