Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - welded in boss' for boxed frames
Old 05-02-2004, 07:19 PM
bhj's Avatar
bhj bhj is offline
member
I'm preparing to box the frame on my 34 ford coupe. I have searched the databases here and can't find the answer to this question.
For the bolts that hold the body and fenders on the frames there is a washer and nut on the inside of the frame, if boxed obviously one can't get to these nuts to tighten or loosen them. So is it acceptable to tack weld a larger diameter washer to the frame then tack the nut to the washer making a welded in boss for adjustments etc.
